Akai Apc 40: No Led-Feedback
Mondmöwe
Post by Mondmöwe »
I need help with my Midi-Controller: Akai apc 40
Arena Resolume 7.21.3
MacbookPro M2 Max, 2021, Sonoma 14.6.1
I have an old Akai Apc 40 controller:, which I got from a friend. I can do the midi-mapping, knobs & buttons are working, but there is no light-feedback to the controller. So even if I press a button > the clip is playing, the button wont light up to show which clip is played
I checked in the preferences Midi Output is activated.
Is there an option to make this work? and if not is there an other controller that works smoother?
Thanks in advance
I already checked the internet & ChatGpt, haven’t found a solution yet.
producation
Re: Akai Apc 40: No Led-Feedback
Post by producation »
Did you only activate the output channel or did you also map it?
If not here is a video that might help. It's for the APC40mk2 but the workflow should be the same.
https://www.youtube.com/watch?v=8Uuki86pCOw
Sjan Top
Post by Sjan Top »
In resolume you need to set the midi clock out, so it sends midi back to your APC40 Mll.
https://resolume.com/support/en/midi-shortcuts
If that does not do anything it is possible that there some resistor lose on the print board of you APC40.
That can easily happen, APC40 Mll are not shock proof. Had to get mein fixed after a slow drop of 50cm.
Mondmöwe
Post by Mondmöwe »
Hi thanks for your answers.
It’ an older Controller – not a MK2-
I couldn’t find the Midi Clock Out, Just Midi Input, Output & Clock in.
I mapped my Midi & it’s the third of those controllers I checked all of them have the same issue (they are working fine, besides the not working LED-Feedback).
Does the MK2 work without problems, and if I connect it does a Midi Clock show up in the preferences, if so. Maybe it’s time for me to get that one.
Thanks a lot
producation
Midi Clock is not needed but you need to activate MIDI Input AND MIDI Output. In the video I posted at around 4:40 he tells how to set the light.
https://youtu.be/8Uuki86pCOw?t=279
https://www.resolume.com/support/en/mid ... s#midi-out
For Clips the state names are different:
- Empty (when there is nothing on the Clip)
- Disconnect (there is a Clip but is not playing)
- Previewing (selected Clip is in Preview Mode)
- Connected (this is when the Clip is playing)
- Connected & previewing (both of the above)
Since I only have the mk2 I don't know for sure it's working on the original APC40 but I would definitely think so. So normally you should only have the option lights on/off maybe there are 127 velocity options available for brightness of the light.
ArtGateOne
Post by ArtGateOne »
In the MIDI settings, select the appropriate input and output for the appropriate controller, slightly below the output. You can also select the controller mode. Select the third one (mode 3 - alternative to Ableton Live mode).
Not all keys have two colors, so this may be confusing, but most executors have the option to select red, green, or orange, as well as flashing options.
During mapping, select red for "Connected," for example. Otherwise, the keys will only light green or off.
After connecting the APC, the controller starts in mode 1 - automatic mode. After starting, Resolume should send a sysexx message switching it to mode 3 (the LED that lights up on startup should go out).
Tested and working.
