Spout / Syphon texture sharing settings?
AllanPill
Post by AllanPill »
Before I start a feature request I thought I'd ask if there has been any discussion in the Resolume team or elsewhere of being able to set texture sharing fps and bit depth.
I'm seeing Arena send out a Spout feed with default 8bit BGRa 60fps, at the defined resolution of the corresponding Advanced Output screen and/or the composition even if composition fps is locked at 25fps.
This results in weird behavior in software down the line when fps matters (commercial shoots etc). The frames don't align and it looks like stutter on screen and in camera.
I've checked PC load and GPU is at a mere 10%, CPU couldn't be bothered and RAM is sitting nicely with a lot of room to spare. So there is no load issue and it should work flawlessly but it does not.
For context, I am asking because I recently had to opt for a workflow of Arena > Spout > other software since Resolume does not have advanced color correction for LED volume filming applications as discussed in this topic:
viewtopic.php?t=19295
I have tested with OBS and Touch Designer. Spout Receiver app gave me the info on FPS and bit depth.
