Audio crackling on last version 7.23
lfavreau
Post by lfavreau »
I have audio crackling issues in video clips in Arena 7.23 and 7.23.1. Even in Alley when I trascode to DXV audio get worse than other codecs, just sound nearly intelligible. I have my Arena installed on a Asus Vivobook with rtx4060 mobile. Someone have this same issue? I have a presentation tomorrow and this drive me crazy. Thx
Re: Audio crackling on last version 7.23
Try changing the audio devcie to the windows - exclusive mode one if you see it.
Or do a computer restart.
I suspect the Windows update I got recently messed up something with the audio driver, I sometimes get audio muted too, with the devcie looking like it's not muted, but muting and unmuting it in the windows audio controls gets it unmuted properly.
lfavreau
Post by lfavreau »
Thx Zoltán.
I found the problem!
It was the audio codec. When I trascoded works well. Avoid this codec.
SAME VIDEO
BAD (crackling):
Code: Select all
Format                                   : AAC LC SBR
Format/Info                              : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name                          : HE-AAC
Format settings                          : NBC
Codec ID                                 : mp4a-40-5
Duration                                 : 17 s 297 ms
Duration_LastFrame                       : -26 ms
Bit rate mode                            : Constant
Bit rate                                 : 70.5 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 44.1 kHz
Frame rate                               : 21.533 FPS (2048 SPF)
Compression mode                         : Lossy
Stream size                              : 149 KiB (6%)
GOOD:
Code: Select all
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : ac-3
Duration                                 : 17 s 201 ms
Source duration                          : 17 s 206 ms
Bit rate                                 : 192 kb/s
Frame rate                               : 28.711 FPS (1536 SPF)
Stream size                              : 403 KiB (11%)
Source stream size                       : 403 KiB (11%)
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
Encoded date                             : 2025-08-09 17:39:35 UTC
Tagged date                              : 2025-08-09 17:39:35 UTC
Dialog Normalization                     : -31 dB
dialnorm_Average                         : -31 dB
dialnorm_Minimum                         : -31 dB
dialnorm_Maximum                         : -31 dB
Can you share the original file at mail@resolume.com?
We'd recommend using DXV video with uncompressed audio for best results.
