Options from Output and Process resolution have disappeared
perno
Post by perno »
The options of menu of configuration of output and process resolution have disappeared. I can unfold menus but it doesn´t appear the resolution sizes.This causes that the resolution of output is of 320x240, with the incovenientes that entail.
I have a dell computer with nvia 7900gs graphic card?
Try deleting the Resolume settings in ~/My Documents/Resolume 2.4/
If that does not help then it could be a video driver issue so you could try re-installing the latest version of your nvidea drivers.
