Mac Studio Pro M4 Crashing *FIXED*
VJCoqui
Post by VJCoqui »
Hi all, I experienced a crash on Resolume and wanted to share a fix. I installed some wire effects today on a Mac Studio Max and when i installed Radical Slice, it wouldn't show up in my effects panel. When i restarted Resolume it proceeded to crash instantly. After trouble shooting for a few hours I found that not even back rolled versions of Resolume would work EXCEPT 7.20.0 and that was the only update version that worked.
The fix? I ended up going into the library folder holding my comp and deleted it. Reinstalled 7.23.2 rev51094 and now it works. Redownloaded my entire Juicebar library and it still works. So be warned, Radical Slice on a Mac OSX may cause your Resolume to crash and generate crazy error logs.
