I'm currently setting up a lighting + media rig for a 24 hour musical at uni (we found out what the show was at 17:00 yesterday, and first performance is 17:00 today!)
However we've run into a problem.
On firing up resolume and enabling Artnet, we found that it periodically broadcasts all channels at zero across all artnet universes, obviously this is annoying our dimmers, and the hippotiser we're also using.
Just wondering if anyone else has seen this, and/or can suggest any fixes!
JMRLD
						Artnet Broadcast noise
update
Hey,
Quick "post show" update on the solution we resorted to.
Having found the only way to stop the artnet broadcasts was to close Resolume, we resorted to disconnecting resolume from Artnet, and selecting the few bits of flash we needed to use manually. Playing the remaining content from the hippotizer under artnet control.
Jamie
PS forgot to post in the last message as was half asleep at the time.
Resolume Ver. 2.41 (and tried a clean reinstall using the newest zip from the website)
Hardware - Thinkpad T43 (2Ghz Pentium M, 512Mb Ram), External HDD for clips, Win XP Pro
Jamie
