Newbie Question - How to hide lower layer?
jeffheart08
Post by jeffheart08 »
Been a long time since I played with Resolume as a part timer. I have a test up with 3 monitors. I am using the default stock footage with a brand new install of the Arena software. I have my main control monitor and 2 displays acting as the screens the customers will see. I have the monitors assigned to the slices I am working with in the advanced setup.
On the top layer, I have it assigned to screen 2, and on the layer under that, I have it assigned with slices to screen 1 and 2 so that layer's footage is spanned across both screens.
Both layers are set to 100% opacity.
When I activate footage on the top layer, it overlays the top layer clip on top of screen 2's clip on the lower layer as expected.
However, I then tried to use blending mode "cut" on the top layer thinking that it would cut out the clip playing on the lower layer on screen 2, while the screen 1 portion of that lower layer would continue to play, since only screen 2 was assigned on the top layer with CUT as the blend mode.
In actuality, no matter what blend mode I chose, the lower layer still shows underneath the top layer.
One of the clips I tested did actually completely hide the screen 2 lower layer clip when I played it on the top level, but all the rest just overlay it.
I am assuming because the clips I am playing perhaps are transparent in the areas where there is no content, that the lower layer shows through?
So simply put, how do I get the top layer clip, no matter what the content is to fully hide the lower layer when the top layer is active?
Thank you for any help in advance
Jeff
Re: Newbie Question - How to hide lower layer?
Blending modes are bypassed by the layer to slice routing. https://resolume.com/support/en/slice-routing
