Successfully using Streamdeck and Resolume companion plugin with 'next column' action to trigger the next column playback in Resolume .
I also have a button that displays the current column using the the plugin variable $(Resolume:connectedColumn)'
Some columns have autopilot set to 'play next column' at end of video (column 3) so that a holding logo is automatically displayed at the end of the video (column 4). This all works well.
However, when autopilot plays next column (column 3 to 4) the companion plugin variable '$(Resolume:connectedColumn)' does not update to 4, it still shows 3, even though Resolume autopilot has just played column 4
The 'next column' action does trigger column 5 correctly...
So the 'next column' and 'last column' actions are tracking the column value correctly, but Resolume is not updating the companion '$(Resolume:connectedColumn)' variable when a column set to autopilot plays the next column.
Is there a fix to update the '$(Resolume:connectedColumn)' variable when a column is set to autopilot 'plays next column'?
Simon
