TCNet Input
djevo1
TCNet Input
Post by djevo1 »
Is there any documentation or recommendations for sending TCNet data in not using the bridge? We have time working and appearing as separate players in resolume but metadata does not seem to work.
Re: TCNet Input
djevo1
Re: TCNet Input
Post by djevo1 »
I know that article, I am asking what the needs are to send TCNet outside of a CDJ player, metadata primarily.
Re: TCNet Input
Where do you want to send the metadata?
djevo1
Re: TCNet Input
Post by djevo1 »
Into resolume, TCnet as a source. Time data works for player registration but sending metadata seems to not be receivable inside of resolume.
Re: TCNet Input
Are you running both apps on the same machine?
Firewalls off?
djevo1
Re: TCNet Input
Post by djevo1 »
Yes, either on same machine or different machine, I see time data flowing but no metadata appears.
Re: TCNet Input
Can you post some screenshots of the interface settings from Resolume, and the Bridge app from the TC-net section?
Are firewalls off?
