good laptop? ....for resolume of course!
wanako
Post by wanako »
hi everyone!!
I want to buy my first laptop for resolume, my budget is $1000 :( :(..
what do you think about this one?
ASUS F3T-AP042C
processor : Turion 64 x2 TL-56 @ 1.8Ghz
memory : 2 GB ram @ 667Mhz
HDD : 120GB @ 5400rpm + 200GB external HDD @ 7200rpm
video : Geforce Go 7600 with 256 dedicated memory
thanx 4 your answers!!!
miau
Post by miau »
I would suggest to chose a different processor type, like the Core2duo 7xxxx series or the new coreduo Santa Rosa and a laptop with e-sata interface to connect to a external HDD or in case the laptop doesn't have a e-sata interface one with a express card slot to put a e-sata card to connect to the external HDD.
There is some solutions in the market around 1000€ or little more.
messhead
Post by messhead »
And you want a 7,200RPM HD in your laptop, 5,400 is SSSSlllllloowwwww
wanako
options!?
Post by wanako »
what about the graphic card, its enough?.. resolume use or not use intensenly the video Card??.. i have another option, a laptop witn C2Duo 7100, 120Gb @ 5400 but with e-sata, and 128MB dedicated video memory (Ati Mobility Radeon X2300) how about this one?..
thanx 4 your help!!
Resolume at the moment does not use the videocard so much but this will change in the future! I,m not familiar with the Radeon X2300 but I think the Geforce Go 7600 is faster.
samarada
Re: good laptop? ....for resolume of course!
Post by samarada »
whats can be wrong with ge force 7600gt,pc have core duo precessor ,2gb ram.when im starting resolume it pops taht to low vidi card specif.thanks.simas
HerrNieDa
Post by HerrNieDa »
maybe you have a "bad" driver...
try another one, maybe the alternative omega drivers
