REAL SIZE VIDEO/IMAGE INSIDE THE SLICE
samirbridi
Post by samirbridi »
I've noticed something, and I don't know if it's a bug or what it really could be, but with a slice of 2566x1680 (for example), if I drop an FHD (1920x1080) screenshot directly into the project, drag it, and only slightly enlarge it to fit within the slice size, it has better quality than when I use the SLICE effect on that screenshot (where even at its original size, it's small). However, when I leave it at the full slice size, it loses quality... this is just an example from a PowerPoint presentation with a lot of text. Why does this happen when using SLICE on images, videos, and sources?
ScottCoumbe
Re: REAL SIZE VIDEO/IMAGE INSIDE THE SLICE
Post by ScottCoumbe »
I have the same question or Issue?
I have not been able to find out the reason behind.
If I have a Slice of 895x100. and my media is 895x100
If I Transform it into the slice, the size is tiny and I have to scale the video 200% to 1000%.
I would have thought that making the media the same size as the slice would have made everything correct and would avoid me scaling.
Pre-Slice Transform.png (210.75 KiB) Viewed 25453 times
Post-Slice Transform.png (214.07 KiB) Viewed 25453 times
Media Size.png (5.3 KiB) Viewed 25453 times
samirbridi
ScottCoumbe wrote: Sun Dec 21, 2025 18:29 I have the same question or Issue?
Apparently I'm not the only one to notice this.
On several occasions, I've encountered this issue and haven't been able to identify the reason. It seems that the slice created doesn't match the file size; that is, if both have the same resolution, the Arena slice loses its identification, requiring us to increase the scale.
I noticed this and it caught my attention more in a recent job I did for a company, where the panel was a bit larger than FHD, something like 2016x1344, and when I put the capture (Blackmagic) inside the slice and asked for the size to be "Original", it simply became much smaller (720p).
I believe it should respect the actual size of the capture, or even the image or video, but it loses the reference and adjusts to a completely different resolution. Because of this, we have to manually adjust, which results in a loss of quality.
Christoph
Post by Christoph »
Have you tried placing your slice transform effect above the native transform effect of the clip?
samirbridi
Christoph wrote: Sun Dec 21, 2025 23:01 Have you tried placing your slice transform effect above the native transform effect of the clip?
In my case, I always apply the "slice" I want to use to the video/image directly without moving its position.
I think it's worth a try, but I shouldn't have to do that every time, right?
samirbridi
What I realized using this solution:
In the case of 1080x1920 images (vertical FHD), when slicing, it managed to fit within the size.
But even at the 3840x1080 size, it became smaller despite the artwork being at the correct resolution, and when I used SliceTransform to increase the size, it filled in, but I noticed that when working with the scale, it doesn't stay centered.
samirbridi
Continuation of the files
samirbridi
Any updates on that last piece of information I posted?
Christoph
Post by Christoph »
Do you have any scaling on the layer/group/composition level going on here?
Can you share your project file (composition and advanced output preset) - feel free to attach here or send to mail@resolume.com
Your transform is after the Slice transform, so the scale happens on the whole texture, not only the area of the slice. At that point your texture size would be the same as the layer resolution.
The first SliceTransform / Transform effect of the clip will render into the layer sized canvas. The next effects will then work with that texture.
We're looking into the option to be able to scale slices inside the slice transform.
