Animation preset issue
mowgli
Post by mowgli »
I'm not sure if it's a bug, an oversight or a feature but...
When saving animation presets the positioning of the in-out brackets of the parameter doesn't get saved.
In my mind, this is an integral part of the animation so I was surprised to find this out.
Re: Animation preset issue
Thanks, indeed, we'll see what we can do.
tijnisfijn
Post by tijnisfijn »
i think this on purpose because than its much easier to re-use you preset on an other parameter. Let's say that you animate the x position and set a range, save as preset and than add that preset to a opacity slider. would you like the same range? most of the time not i think but you do what the animation setting. keeping the range out feels logical for me.
