A touch screen friendly version of Resolume
DayVeeJay
Post by DayVeeJay »
Would totally rock!!!
A touch screen optimized interface requires a complete overhaul because there is no right-click and widgets need to be larger. We,re waiting for proper multi-touch before we spend any time on this.
Basic
Post by Basic »
yeah would be cool! specially when you phished :)
DayVeeJay
Post by DayVeeJay »
Thanks for the response Bart. I completely forgot about the right click button.
Danger
Post by Danger »
if resolume had a "command host" we cold develop diferent interfaces...
VJzoo
Post by VJzoo »
aparently dell are bringing a tablet our with multi touch :)
http://gizmodo.com/gadgets/tablet-pcs/d ... 322955.php
Great that dell is creating a multi-touch tablet but we need an operating system level API to handle the incomming touches. If dell releases it's own multi-touch api specifically for their hardware then it will be a nightmare to support various manufacturers. Does anyone have any details on this?
benaline
Re: A touch screen friendly version of Resolume
Post by benaline »
Obviously not the answer for multi touch screens as the software is going to have to support its use somehow, but touchscreens for resolume work fine here. The driver software gives good right click support through just clicking on screen for a couple of seconds whilst keeping it still. It knows if you're moving about and treats that as a click and drag, suitable for faders etc...
gpvillamil
Post by gpvillamil »
I've used Resolume on a tablet PC with a touch screen, it works fine! Especially for the clip grid.
It's an IBM X61 Tablet, with both touch and stylus.
For right-click, either press-and-hold or use the stylus button.
It would be nice if the widgets could be made a bit bigger.
VjSky
Post by VjSky »
There is one thing that would be perfect since multitouch screens will most definitely be extremely expensive. Now standard touchscreens are great for some simple things like blackout triggering and so. it would be nice if you could make a clone interface that would only have triggers and layer selector/blackout and some simple thigs that wolud be touch friendly and display both the main working screen and the touch panel on different monitors.
