hi guys.
I need to convert mostly all my resolume clips to a different size and obviously don't want to have to re-edit them all individually as there is 2500+ of them so i need a converter that will do them all on it's own. I need to change the resolution as they appear to be several different sizes although most of them are 768x576.
normally i would use river past video cleaner pro but this doesn't have any option to preserve the keyframe every 1 frame,
Anyone know of any converters that will do this and do several in one go (like river past does)?
any help much appreciated
cheers
video clip conversion
superveillance
u could be a little less vague and show the man a link... it is a free program so a I guess I can link it
http://superdownloads.uol.com.br/redir.cfm?softid=26761
Well I recommend you read the links in this page http://sleepytom.co.uk/virtualdub and use VirtualDub job batch capabilities.
superveillance
I always use automator (that comes with mac osx).
It uses the last preferences of quicktime, and encodes it with quicktime as well.
The only problem with that is - it opens all the movies and then converts them... so my mac can't handle it anymore after a while (and it looks a bit messy)..
But I don't think you have a mac...
