txt in flash files
noc_
Post by noc_ »
loading flash files i should have the possibility to write text real time. right?. but i cant. possible or sciencefiction? how can i do?
tnx
noc
check tha manual that is installed with resolume!
- Dynamic flash text
Dynamic text in flash movies. Create your own flash movie with a text field with a variable. Enter the text that it should display in Resolume. This way you can use your own style animations and also be very flexible with the text that you enter. Every time you do a show you can use the flash movie but make it display different text in Resolume.
Right-Click a channel containing a flash movie in resolume and enter your desired text. You can also drag a .txt file from the browser into a channel. Resolume fill a variable called 'text' in your flashmovie, the it is up to you to do something with that varaible. If you make an dynamic text field in flash with the name text it will set this variable, otherwise this variable will a global variable in your falsh movie wich you can use in your actionscripts. We put some samples of flash movies in the flashtext folder of resolume, so you can see how it's done and find out how to create your own. Further explanations of this issue will be done in the manual of resolume 1.1.
aada_
Post by aada_ »
asdasd
