Can you guys answer a few questions for me?
1/ Will Resolume Avenue 3 work well with a Codanova VMX midi controller (are they easy to configure together)?
2/ How many effects can I layer on top of one another at any one time?
3/ Can I adjust how quickly a clip fades in or out when it is being triggered, ie on note release will the clip stop playing sudenly or fade out gradually, is this definable in any way.
4/ Can I load Audio generators like synths and samplers in to Resolume Avenue 3, for example Kontakt or Direct Wave? once loaded will I still be able to access all of their peramiters via midi.
5/ How do I configure Resolume Avenue 3 for a 3 projector set up? ie a different group of clips per screen?
6/ Can Resolume handle hi res midi (14 bit) or does it have midi smoothing to stop "steppy" panning etc?
7/ is there anyway I can use timecoded vynil to scratch VT within resolume, is there any kind of plugin that I can use within Resolume Avenue 3 to achieve this if Resolume Av 3 can't do it?
8/ How do I add free frame effects?
Thanks in advance for any of your time, I realise these may be newb questions so I figured it best to get them all out of the way at once
