We have just released a new Resolume 3 Beta, version rev1110. This new beta is a lot more stable, fixes a lot of bugs and adds live video recording!
In the coming weeks we'll be working on some more improvements and new features like transport controls on the layers, audio FFT analysis and flash playback.
Please download and give it a go.
New features:
- Live video recording!
- Contextual keyboard & MIDI mapping for the entire deck, so it works more like Resolume 2
- Scale clip to composition size (SHIFT + F)
- Timeline on pictures & sources
- Check for updates in the preferences
- About screen
Bug fixes:
Fixed: "The Nvidia Bug" Frozen video ouput on second display when using nvidia card on the pc
Fixed: OSC input (see the manual for details)
Fixed: Some ASIO devices do not work
Fixed: Only 75 .avi files can be opened at the same time
Fixed: Mask makes image darker
Fixed: Vsync in windows does not work
Fixed: Switching to BPM sync causes crash with video clips
Fixed: Quartz Composer file rendered to Quicktime movies don't work
Fixed: Loading a transparent quicktime (animation codec) crashes Avenue
Fixed: Crash when switching decks while preview monitor is playing a clip
Fixed: MIDI clock does not always work
Fixed: Bounce and Play Once don't work for video in BPM mode
Fixed: Audio & video go out of sync when using shortcuts to toggle < >.
Fixed: Flickering output when using pictures and feedback
Improvements:
- Don't update the clip property panel for each clip when loading a deck or composition
- Show proper device names for the capture input sources
- Much less cpu usage on Quicktime video files with uncompressed audio
And many, many other small bug fixes and improvements.
New Beta: Resolume Avenue 3 rev1110
Re: New Beta: Resolume Avenue 3 rev1110
cool cool ! will definately give it a try~
This is great!!!!
Fixed: Loading a transparent quicktime (animation codec) crashes Avenue Hope this work
Quick question how the live video recording works?
I don´t know is it all ready possible to do it, but can the wav be moved in the clip.
Like if i have movie file example.. vinyl scratch and then i have wav sound scratch i combine them
the sound start before the hand on the video touches the vinyl and start scratch. So i have to move the sound couple second back, can i make it sync in resolume?
Sorry my english....
Press the record buttonandrei wrote:Quick question how the live video recording works?
it's on the right of the screen
you can find the recorded file as a quicktime in the "recorded" folder
- Attachments
- rec.jpg (4.17 KiB) Viewed 29717 times
MacBook Pro, OSX 10.6.1, 2,5GHz, 4GB RAM, Nvidia Geforce 8600 GT 512MB, Edirol PCR-300, Ableton Live 8.0.5
bart wrote:Press the record buttonandrei wrote:Quick question how the live video recording works?
Yes i am blind
craftycurate
Great thanks - will give it a whirl this weekend.
There is no sound record whit the video record??
that's also what i wanted to ask...andrei wrote:There is no sound record whit the video record??
VibemasterBert
it seems the "empty-decks" problem isnt fixed
every time i start r3 on my macbook pro, i got 7-8 empty decks and the programm isnt able to remember the last decks i used.
