When it was announced I got really happy because previous version was not to stable to convince me to purchase. Then I downloaded the latest beta (rev1110). Loaded a video clip (640 x 480 .mov file) with separate Audio file (Wav format). Soon enough while assigning my Akai Mpd 32 to trigger the video Resolume crashes! Video recording works but does not record audio ? Video clips sometimes play slow and not in sync with actual audio file.
Things that I like about Resolume 3
Easy use
Cue points
Beat Loop
Combine Video & Audio Effects
Multiple Layers
Adjustable workspace.
Wish you guys add a sequencer like Ableton
here are my computer specs
iMac 2.0 ghz Intel core 2 Duo with 2 Gigs of Internal Ram, ATI Radeon X1600 with 128MB GDDR3. with a second 21" Monitor. running OS Leopard 10.5
