after installation, impossible to open.
VjRobotX
Post by VjRobotX »
I have no problem with opening resolume 3 Beta
but with resolume final, impossible to open.
I followed all your advice for the drivers.
Here are the results :
OpenGL REport
Renderer: GeForce 8700M GT/PCI/SSE2
Vendor: NVIDIA Corporation
Memory: 512 MB
Version: 2.1.2
Shading language version: 1.20 NVIDIA via Cg compiler
Max number of light sources: 8
Max viewport size: 8192 x 8192
Max texture size: 8192 x 8192
Max anisotropy: 16
Max samples: 32
Max draw buffers: 8
Max texture coordinates: 8
Max vertex texture image units: 32
Extensions: 161
GL_ARB_color_buffer_float
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_half_float_pixel
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_shader_objects
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_transpose_matrix
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_Cg_shader
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_EXTX_framebuffer_mixed_formats
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KTX_buffer_region
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_half_float
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_texgen_reflection
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NVX_conditional_render
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_ARB_buffer_region
WGL_ARB_extensions_string
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_ARB_render_texture
WGL_ATI_pixel_format_float
WGL_EXT_extensions_string
WGL_EXT_framebuffer_sRGB
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control
WGL_NV_float_buffer
WGL_NV_multisample_coverage
WGL_NV_render_depth_texture
WGL_NV_render_texture_rectangle
Core features
v1.1 (100 % - 7/7)
v1.2 (100 % - 8/8)
v1.3 (100 % - 9/9)
v1.4 (100 % - 15/15)
v1.5 (100 % - 3/3)
v2.0 (100 % - 10/10)
v2.1 (100 % - 3/3)
v3.0 (85 % - 18/21)
OpenGL driver version check (Current: 2.1.2, Latest known: 2.1.2):
Latest version of display drivers found
According the database, you are running the latest display drivers for your video card.
No ICD registry entry
The current OpenGL driver doesn't expose the SOFTWARE/Microsoft/Windows (NT)/CurrentVersion/OpenGLDrivers registry entry. Unable to detect the driver version, driver revision name and filename.
Compiled vertex array support
This feature improves OpenGL performance by using video memory to cache transformed vertices.
Multitexture support
This feature accelerates complex rendering such as lightmaps or environment mapping.
Secondary color support
This feature provides an alternate method of coloring specular highlights on polygons.
S3TC compression support
This feature improves texture mapping performance in some applications by using lossy compression.
Vertex array range support
This feature improves performance in some applications by using AGP for dynamic vertex transformation.
Texture edge clamp support
This feature improves texturing quality by adding clamping control to edge texel filtering.
Vertex program support
This feature enables a wide variety of effects via flexible vertex programming (equivalent to DX8 Vertex Shader.)
Fragment program support
This feature enables a wide variety of effects via per pixel programming (equivalent to DX9 Pixel Shader.)
Texture anisotropic filtering support
This feature improves the quality of texture mapping on oblique surfaces.
Occlusion test support
This feature provides hardware accelerated culling for objects.
Point sprite support
This feature improves performance in some particle systems.
OpenGL Shading Language support
This feature enables high level shading language for shaders.
Frame buffer object support
This feature enables render to texture functionality.
Extension verification:
GL_EXT_color_subtable was not found, but has the entry point glColorSubTableEXT
GL_EXT_copy_texture was not found, but has the entry point glCopyTexSubImage3DEXT
GL_EXT_paletted_texture was not found, but has the entry point glColorTableEXT
GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableEXT
GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableParameterfvEXT
GL_EXT_paletted_texture was not found, but has the entry point glGetColorTableParameterivEXT
GL_EXT_subtexture was not found, but has the entry point glTexSubImage3DEXT
GL_KTX_buffer_region has the entry point glBufferRegionEnabledEXT missing!
GL_KTX_buffer_region has the entry point glDeleteBufferRegionEXT missing!
GL_KTX_buffer_region has the entry point glDrawBufferRegionEXT missing!
GL_KTX_buffer_region has the entry point glNewBufferRegionEXT missing!
GL_KTX_buffer_region has the entry point glReadBufferRegionEXT missing!
GL_NV_geometry_program4 was not found, but has the entry point glProgramVertexLimitNV
GL_NV_half_float has the entry point glVertexWeighthNV missing!
GL_NV_half_float has the entry point glVertexWeighthvNV missing!
GL_NV_present_video was not found, but has the entry point glGetVideoi64vNV
GL_NV_present_video was not found, but has the entry point glGetVideoivNV
GL_NV_present_video was not found, but has the entry point glGetVideoui64vNV
GL_NV_present_video was not found, but has the entry point glGetVideouivNV
GL_NV_present_video was not found, but has the entry point glPresentFrameDualFillNV
GL_NV_present_video was not found, but has the entry point glPresentFrameKeyedNV
WGL_NV_swap_group was not found, but has the entry point wglBindSwapBarrierNV
WGL_NV_swap_group was not found, but has the entry point wglJoinSwapGroupNV
WGL_NV_swap_group was not found, but has the entry point wglQueryFrameCountNV
WGL_NV_swap_group was not found, but has the entry point wglQueryMaxSwapGroupsNV
WGL_NV_swap_group was not found, but has the entry point wglQuerySwapGroupNV
WGL_NV_swap_group was not found, but has the entry point wglResetFrameCountNV
WGL_NV_vertex_array_range was not found, but has the entry point wglAllocateMemoryNV
WGL_NV_vertex_array_range was not found, but has the entry point wglFreeMemoryNV
WGL_NV_video_output was not found, but has the entry point wglBindVideoImageNV
WGL_NV_video_output was not found, but has the entry point wglGetVideoDeviceNV
WGL_NV_video_output was not found, but has the entry point wglGetVideoInfoNV
WGL_NV_video_output was not found, but has the entry point wglReleaseVideoDeviceNV
WGL_NV_video_output was not found, but has the entry point wglReleaseVideoImageNV
WGL_NV_video_output was not found, but has the entry point wglSendPbufferToVideoNV
Resolume Avenue 3.0.0 Log
Log started: 18 Mar 2009 3:55:15 pm
logging has started
system language is: en
registration valid
hd serial valid
serial has not expired
Instantiate midi controller
Create ApplicationParameterCollection
Create ApplicationPropertyCollection
create video engine state object
getApplicationVFXPath: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx
create audio engine state object
getApplicationAFXPath: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx
create application lookups
create file loader
start loading application settings
set language
Hello = Hello
ScreenSetup, remove diconnected displays
ScreenSetup, add newly found displays
ApplicationPropertyCollection, load contextual shortcuts from disk
ApplicationPropertyCollection, check for user configured keyboard shortcuts
ApplicationPropertyCollection, midi file path C:\Users\VjRobotX\Documents\Resolume Avenue 3\preferences\contextualMidiShortcuts.xml
initialize quicktime
create playback controller
create composition object
create GUI
load help file
create audio/video plugin collection
create video engine
Generic PnP Monitor NVIDIA GeForce 8700M GT {ADCE6E9D-1A0D-4787-A89F-DE7297E44EDF
new context is created
Init glew succeeded
name main GL renderer: GeForce 8700M GT/PCI/SSE2
version GL driver main renderer: 2.1.2 atof: 2.0999999
No support for GLEW_ARB_texture_non_power_of_two
nonpoweroftwo NOT supported
GLEW_EXT_framebuffer_object supported
GLEW_ARB_pixel_buffer_object supported
glCheckFramebufferStatusEXT
GL_FRAMEBUFFER_COMPLETE_EXT!
find video plugins and add them to the plugin collection
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGL3dPixels.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLAddSubtract.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLBrightnessContrast.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLColorize.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLColourPass.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLCreateAlphaChannel.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLFlip.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLFreeze.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLGradients.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLInvertRGB.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLLumaWaves.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLParticles.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLPixelHighPass.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLPointGrid.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLRotateXMixer.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLRotateYMixer.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLSolidColor.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLStingySphere.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLThreshhold.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLTrails.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLWipeDown.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLWipeLeft.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLWipeRight.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLWipeUp.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLZoomMixer.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\AVFFGLZoomMixerOut.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLAdd.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLAdd50.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLAddMaskUtility.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLAlpha.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLBlow.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLBlur.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLBurn.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLCircles.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLDarken.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLDifference.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLDifferenceInverse.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLDistortion.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLDodge.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLExposure.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLFilmBleach.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLHeat.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLHueRotate.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLKaleidoscope.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLevels.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLighten.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLighten50.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLorez.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLumaDisplace.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLumaIsAlpha.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLumaKey.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLLumaKeyInverse.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLMirror.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLMultiply.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLPosterize.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLRGBASwitch.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLSaturation.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLScreen.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLSlide.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLSoftLight.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLSqueeze.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLSubtract.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLTile.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\FFGLTwirl.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Colourise.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Fragment.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Goo.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Iterate.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Kaleidoscope.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_RadialBlur.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Ripples.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Stripper.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Tunnel.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_VideoWall.dll
load succeeded
load plugin: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\vfx\SyzGL_Vignette.dll
load succeeded
begin Setup secondary contexts
end Setup secondary contexts
create audio engine
Adding destination (address: 185819688) to audio callback, inputPair are 0
Succesfully added destination with index
opening dsound out device: Périphérique audio principal rate=44100 bits=16 buf=960
opening dsound out step 2
opening dsound out step 3
opening dsound in device: Pilote de capture audio principal rate=44100 bits=16 buf=960
opening dsound in step 2
Signature du problème :
Nom d’événement de problème: APPCRASH
Nom de l’application: Avenue.exe
Version de l’application: 0.0.0.0
Horodatage de l'application: 49b92d34
Nom du module par défaut: mafwasio.dll
Version du module par défaut: 5.10.0.5055
Horodateur du module par défaut: 48f644e4
Code de l’exception: c0000005
Décalage de l’exception: 00001837
Version du système: 6.0.6001.2.1.0.256.1
Identificateur de paramètres régionaux: 1033
Information supplémentaire n° 1: fd00
Information supplémentaire n° 2: ea6f5fe8924aaa756324d57f87834160
Information supplémentaire n° 3: fd00
Information supplémentaire n° 4: ea6f5fe8924aaa756324d57f87834160
I could open it 2 times, after 10 time
Windows Vista Edition integrale 64 Bit
Service pack 1
Processor : Intel(R) Core (TM)2 Duo CPU T9300 @ 2,50 GHz
Memory : 4.00 Go Ram
I do not understand why the Beta version with no problem and that the final version yes
and finally, I say, but since the French version
thank you for your help
Re: after installation, impossible to open.
Hmm we have heard from one other person who had problems with Windows Vista 64 Bit Edition. We have not tried this one yet so we,ll investigate.
What you can try is delete this folder and then start again:
~/My Documents/Resolume Avenue 3/preferences/
VjRobotX
Post by VjRobotX »
the preference file was empty because I had to uninstall Resolume reinstalled.
after three times it just opened here is the result
I am not optimistic because I know once closed it will never do. A uninstall and installed again
Log started: 18 Mar 2009 11:31:46 pm
logging has started
registration valid
hd serial valid
create file loader
set language
Hello = Hello
Added: DISPLAY1 DISPLAY1 - NVIDIA GeForce 8700M GT
ApplicationPropertyCollection, no user configured keyboard shortcuts found
ApplicationPropertyCollection, midi file path C:\Program Files (x86)\Resolume Avenue 3.0.0\default\contextualMidiShortcuts.xml
create GUI
load help file
create video engine
Init glew succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
create audio engine
Adding destination (address: 177140944) to audio callback, inputPair are 0
Unable to open None, opened Périphérique audio principal instead.
Adding source (address: 177234440) to audio callback, outputPair is 1
Succesfully added source with index
Adding source (address: 177234984) to audio callback, outputPair is -1
Changing audio setup to:
Output Device: Périphérique audio principal
Input Device: Pilote de capture audio principal
Samplerate: 44100
BlockSize: 960
closing dsound in: Pilote de capture audio principal
closing dsound out: Périphérique audio principal
Changed inputPair on destination 0 (address 177140944) to -1
find audio plugins and add them to the plugin collection
Attempting to load VST: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx\vst\Resolume Bitcrusher.dll
Creating VST instance: Resolume Bitcrusher
Initialising VST: Resolume Bitcrusher
Attempting to load VST: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx\vst\Resolume Distortion.dll
Creating VST instance: Resolume Distortion
Initialising VST: Resolume Distortion
Attempting to load VST: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx\vst\Resolume EQ-3.dll
Creating VST instance: Resolume EQ-3
Initialising VST: Resolume EQ-3
Attempting to load VST: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx\vst\Resolume Flanger.dll
Creating VST instance: Resolume Flanger
Initialising VST: Resolume Flanger
Attempting to load VST: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx\vst\Resolume High-Pass.dll
Creating VST instance: Resolume High-Pass
Initialising VST: Resolume High-Pass
Attempting to load VST: C:\Program Files (x86)\Resolume Avenue 3.0.0\plugins\afx\vst\Resolume Low-Pass.dll
Creating VST instance: Resolume Low-Pass
Initialising VST: Resolume Low-Pass
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
load succeeded
start file loader, if autoload directories are present they will be loaded now
mainwindow, update lists
start audio engine
start render engine
begin GlEngine start
end GlEngine start
initializes the ApplicationPropertyCollection, opens up osc and
osc receive disabled
osc send disabled
start playback controller
Initialise midi controller, start devices
Samplerate: 44100
BlockSize: 960
MidiController, stop and close midi devices
clean up audio engine
Trying to remove destination (address: 177140944)
Succesfully removed destination with index
clean up audio state object
clean up video engine
clean up video state object
clean up composition settings holder
clean up GUI
clean up file loader
clean up playback controller
clean up application property collection
clean up ApplicationPropertyCollection
clean up MidiController
clean up ApplicationParameterCollection
clean up pluginCollection
I hope that this result may help you
