Avenue crashes in bacbookPro
srpause
Post by srpause »
hi,
I send here attached the report from my intel macbookPro, after Avenue crashed many times, while changing from A to B file browser panels, or simply loading clips into decks.
My last crash was five min. ago with 3.0.1 installed
¿any ideas?
informeFalloResolume2.zip
inform of failures in Avenue
(9.59 KiB) Downloaded 882 times
Re: Avenue crashes in bacbookPro
What kind of video files are you using?
Please send me the log file that Avenue creates on your computer:
MAC: /Users/[username]/Library/Logs/Resolume Avenue 3 log.txt
PC: C:/Documents and Settings/[username]/Application Data/Resolume/Resolume Avenue 3 log.txt
Hopefully that will show us what is going wrong.
srpause
Post by srpause »
hi,
I´ve been using mostly .mov (photoJPG) and some .avi (DV, cinepack). videos with 720x576 give me problems.
Attached, the report from Avenue.
thanks!
Resolume Avenue 3 log.txt.zip
Avenue Log
(4.82 KiB) Downloaded 862 times
vjloco
Post by vjloco »
DV is not a good codec to use with Resolume. For AVIs the best codec is Indeo. For .movs you should use the new DXV codec from Resolume.
Laptop: Intel Core 2cpu T7200 @2Ghz - 2Gig Ram
Operating system: Windows Vista Ultimate Sp1 X64
Video card: NVIDIA Gforce Go 7600
VibemasterBert
Post by VibemasterBert »
i had the same problem on my macbook pro.
all my clips were mov (photoJPG) - as recommended in the tutorial and i got a crash around every 5 minutes.
so i converted all files to the new dxv-codec. this was a long work and 2 computers rendered nearly 48h to do - but it was worth!
all decks are loading much faster now and i got no single crash in my last 6h set.
big thank you and thumb up for the new codec.
srpause
Post by srpause »
well, so rendering again is the solution.... let`s try, and thanks!
punkcake
Post by punkcake »
it crashed in my macbook pro too.
where can I find that codec... are you sure thats the solution.. i have tons of videos in .mov....
VibemasterBert
if you use avenue 3 final und allready have the codec.
use a batch-converter like (Livid Istruments Batch Export Utility)
http://www.lividinstruments.com/support_downloads.php
i tried media converter cs4 and got a lot of wrong clips, but with the lividinstruments batch converter everything was finde - you only need a lot of time ,-)
punkcake
Post by punkcake »
hi now what you are telling me is to change all my .mov files with dis dxv codec?
The result is a similar file with extension .mov, right?
punkcake
Post by punkcake »
sorry, one more question.
When i am ding videos in Final Cut, can I export it with COMPRESSION DXV? Thats the solution? to have those files with codec DXV?
