Hey, just came across this: http://vvvv.org/tiki-index.php?page=OSCGlue
It is a VST plugin that converts parameter inputs into OpenSoundControl messages, and sends them out over UDP.
Could this be a good/easy way to link Ableton and Resolume?
(Also Max/MSP to Resolume via OSC works well, will post more info later in the week)
Control Resolume from Ableton via OSC
- gpvillamil
Re: Control Resolume from Ableton via OSC
I would suggest using Max For Live. I am working on a interface for connecting Live to various VJ apps. Resolume is definitely one of the APPs I am going to be showcasing.
Regards,
Mike
site: max4live.info
Regards,
Mike
site: max4live.info
davidbayles
mchenetz, what kind of functionality/features are you going to have? what are the major advantages over midi?
Hey Mike,mchenetz wrote:I would suggest using Max For Live. I am working on a interface for connecting Live to various VJ apps. Resolume is definitely one of the APPs I am going to be showcasing.
Regards,
Mike
site: max4live.info
I'm very interested in the interface you're building, do you have any idea when we can try it out?
grtz, Freek
Hi mchenetz
How is it going with the max4live controlling VJ apps project? I'm really keen to start controlling Resolume using OSC. Are there any good starting examples? I know a bit of max so could attempt to cobble something together myself.
- rxfromparis
i'm installing max for live now, would be interested for testingmchenetz wrote:I would suggest using Max For Live. I am working on a interface for connecting Live to various VJ apps. Resolume is definitely one of the APPs I am going to be showcasing.
Regards,
Mike
site: max4live.info
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
