loading decks in version 1.5
Lucidhouse_
Post by Lucidhouse_ »
Hi
I've used resolume for 2 years now and am very pleased with it...
Thank you for a great piece of software.
One big problem for me in version 1.5 is that when I load a new deck (deck -005) the clips that are busy playing in the 3 chanels from the previous deck (deck-004) are instantly replaced by 3 clips from the new deck, this did not happen in version 1.4. Why the change? Is It a bug? That was a very good function for live performances, you could choose when and what you wanted at the right time of asking!
I am now only using version 1.4 for live gigs because I can't have the wrong clips loading up when I don't want them. Please guys put that function back in.
Regards
Morris
http://www.lucidhouse.com
DinkyToys_
Post by DinkyToys_ »
Maybe also a good consideration to putting more then one page of clips for one deck. Sometimes you want to play 2 avi's from an other clip then you have first to find the avi then put some effect on it and then you can set it on a layer.
TranZenDent have +/- 8 banks with 10 clips per bank.
mat_
Post by mat_ »
yes! i.ve noticed this change as well, it is not very logical, when loading new deck the clips that are playing in channels get instantly replaced by new deck clips, maybe you have some clips there that are not suitable to the music you're jaming with so it is not helpfull.
Version 1.4 worked great when loading new deck couse the clips playing in chanels from previous deck caried on playing till you replaced them with new set.
ether_warpTV_
Post by ether_warpTV_ »
i agree - the previous version was better with regards to loading new decks. Since the new version i've only been working band gigs where it's not a problem as there's a gap between songs - i will probably go back to the previous version for dance events so am able to load new decks without interupting the flow of the mix.
zeist_
Post by zeist_ »
when you load a new deck you can select the clip(s) you want to _NOT_ load... so the clip(s) you want to keep (in the corresponding slot) will stay there sweat as!!
that is fully logical :) _b
Lucidhouse_
Ok... never even knew about that function, thanks for tip...i must say I still liked the way loading decks worked in 1.4, it just gave you the option of having more clips at your disposal...
it's a beutiful piece of software none the less
cheers
Dan_
Post by Dan_ »
another possibility you might want to consider is creating decks that only load clips into the first 10 or last 10 slots - that way you can stagger your loading of decks.
Dan.
download the nev version (1.51) ... we have restored the old deck switching behaviour
Lucidhouse_
Thanx
For fixing it guys
you're stars!
