right-click bug
jacob_
Post by jacob_ »
i've been using resolume for a few weeks in a club and am really impressed, in fact just bought it - however - i've noticed that frequently, when i right-click a clip to access the loop/bounce/once options, it will open those options for a different clip, and then refuse to let me change those settings on any other clips from there out, with every different right-click it just accesses settings for the same clip over & over. any ideas? has anybody else experienced this?
jacob stone / punch drunk
seattle, usa
edwin
Post by edwin »
this is a bug,
wich is fixed but we haven't released a new version yet. We will do this as soon as possible.
jacob_
Post by jacob_ »
how can i cope with this problem currently? are there any tricks which will shake the bug during use? or do i need to restart the program each time? perhaps you guys can make a quick patch? i'm on the verge of doing a few major rock tours with resolume, and so far, aside from that i'm totally ready to use it as my main program source. thanks so much!
seattle, usa
ether_warpTV_
Post by ether_warpTV_ »
drop an effect onto a different clip, then try right-clicking this as if to adjust the effect options. I've found this brings up the correct right-clicked box (after one or two clicks)
