3.1 Clip scale BPM sync used to retrigger from start
zeropoint
Post by zeropoint »
Previously, if I set clip scale to bpm sync, the scale slider would reset to it's start point when the clip was retriggered.....now it does not.
Macbook Pro 17" 2.93ghz, 4G Ram, OSX 10.5.7, Live 8.2.2, Avenue 3.3.1, Faderfoxes LV2,DJ2, LD2, Monome 40h.
Re: 3.1 Clip scale BPM sync used to retrigger from start
Correct, the problem with the old method is that is was always out of sync. Now it's allways on par wth the global BPM counter.
