Benchmarking
HerrNieDa
Benchmarking
Post by HerrNieDa »
please post your framerates, composition resolution and number of layers and effects (not ecaxtly ;) )
and your hardware config, i thing the interesting thing is the graphic card!
i want to know if you get higher framerates in higher resolution caused of graphic memory or gpu power....
there are f.e. 9600 geforce cards with 2gb ram! and they are not very expensive or even much cheaper compared to a newer, better graphic-card with less memory!
