Res3 Crashes on launch on a macbook pro
heppner
Post by heppner »
I'm gonna to buy Res3 so I've installed demo version, but...
the app splash screen shows up then the resolume window, stays black for 2-3 seconds then closes,
the effect is the same for ver. 3.0.0 and 3.0.1
MacBook Pro
Mac OS X 10.5.8
2,6 GHz Intel 80486 x 2
4 GB SDRAM
1920 x 1200 x 32 bpp
logs and OpenGL report below:
Resolume Avenue 3.1.2 rev2086
Log started: 3 Oct 2009 2:56:34 pm
logging has started
Operating system: Mac OS X
OS 64 bit: No
CPU vendor: GenuineIntel
CPU speed: 2600MHz
Number of CPUs: 2
Memory size: 2047MB
system language is: pl
registration invalid
hd serial invalid
serial has not expired
Instantiate midi controller
Create ApplicationParameterCollection
Create ApplicationPropertyCollection
create composition state object
create video engine state object
getApplicationVFXPath: /Applications/Resolume Avenue 3.1.2\plugins\vfx
create audio engine state object
getApplicationAFXPath: /Applications/Resolume Avenue 3.1.2\plugins\afx
create application lookups
create file loader
start loading application settings
set language
Hello = Hello
ScreenSetup, remove diconnected displays
ScreenSetup, add newly found displays
Added: Display1 Display1 - GeForce 8600M GT
ApplicationPropertyCollection, load contextual shortcuts from disk
ApplicationPropertyCollection, check for user configured keyboard shortcuts
ApplicationPropertyCollection, no user configured keyboard shortcuts found
ApplicationPropertyCollection, midi file path /Applications/Resolume Avenue 3.1.2\default\contextualMidiShortcuts.xml
initialize quicktime
create playback controller
create composition object
create GUI
load help file
create audio/video plugin collection
create video engine
Renderer: NVIDIA GeForce 8600M GT OpenGL Engine
Vendor: NVIDIA Corporation
Memory: 512 MB
Version: 2.0 NVIDIA-1.5.48
Shading language version: 1.20
Max texture size: 8192 x 8192
Max texture coordinates: 8
Max vertex texture image units: 16
Max texture image units: 16
Max Geometry Texture Units: 16
Max anisotropy: 16
Max number of light sources: 8
Max viewport size: 8192 x 8192
Max uniform vertex components: 4096
Max uniform fragment components: 4096
Max Geometry Uniform Components: 2048
Max varying floats: 40
Max samples: 0
Max draw buffers: 8
Extensions: 112
GL_APPLE_aux_depth_stencil
GL_APPLE_client_storage
GL_APPLE_element_array
GL_APPLE_fence
GL_APPLE_float_pixels
GL_APPLE_flush_buffer_range
GL_APPLE_flush_render
GL_APPLE_object_purgeable
GL_APPLE_packed_pixels
GL_APPLE_pixel_buffer
GL_APPLE_specular_vector
GL_APPLE_texture_range
GL_APPLE_transform_hint
GL_APPLE_vertex_array_object
GL_APPLE_vertex_array_range
GL_APPLE_vertex_program_evaluators
GL_APPLE_ycbcr_422
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_half_float_pixel
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_shader_objects
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_transpose_matrix
GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_ATI_texture_env_combine3
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_transform_feedback
GL_IBM_rasterpos_clip
GL_NV_blend_square
GL_NV_depth_clamp
GL_NV_fog_distance
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_light_max_exponent
GL_NV_multisample_filter_hint
GL_NV_point_sprite
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_texgen_reflection
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
Core features
v1.1 (100 % - 7/7)
v1.2 (100 % - 8/8)
v1.3 (100 % - 9/9)
v1.4 (100 % - 15/15)
v1.5 (100 % - 3/3)
v2.0 (100 % - 10/10)
v2.1 (100 % - 3/3)
v3.0 (52 % - 12/23)
v3.1 (12 % - 1/8)
v3.2 (11 % - 1/9)
OpenGL driver version check (Current: 2.0 NVIDIA-1.5.48, Latest known: 2.0 NVIDIA-1.5.48):
Latest version of display drivers found
According the database, you are running the latest display drivers for your video card.
Compiled vertex array support
This feature improves OpenGL performance by using video memory to cache transformed vertices.
Multitexture support
This feature accelerates complex rendering such as lightmaps or environment mapping.
Secondary color support
This feature provides an alternate method of coloring specular highlights on polygons.
S3TC compression support
This feature improves texture mapping performance in some applications by using lossy compression.
Vertex array range support
This feature improves performance in some applications by using AGP for dynamic vertex transformation.
Texture edge clamp support
This feature improves texturing quality by adding clamping control to edge texel filtering.
Vertex program support
This feature enables a wide variety of effects via flexible vertex programming (equivalent to DX8 Vertex Shader.)
Fragment program support
This feature enables a wide variety of effects via per pixel programming (equivalent to DX9 Pixel Shader.)
Texture anisotropic filtering support
This feature improves the quality of texture mapping on oblique surfaces.
Occlusion test support
This feature provides hardware accelerated culling for objects.
Point sprite support
This feature improves performance in some particle systems.
OpenGL Shading Language support
This feature enables high level shading language for shaders.
Frame buffer object support
This feature enables render to texture functionality.
Extension verification:
GL_APPLE_rgb_422 was not found, but is available in driver version 2.1 NVIDIA-1.6.0
GL_ARB_color_buffer_float was not found, but is available in driver version 2.1 NVIDIA-1.6.0
GL_ARB_half_float_vertex was not found, but is available in driver version 2.1 NVIDIA-1.6.0
GL_EXT_framebuffer_sRGB was not found, but is available in driver version 2.1 NVIDIA-1.6.0
Process: Avenue [240]
Path: /Applications/Resolume Avenue 3.1.2/Avenue.app/Contents/MacOS/Avenue
Identifier: com.resolume.avenue
Version: 3.1.2 (3.1.2)
Code Type: X86 (Native)
Parent Process: launchd [65]
Interval Since Last Report: 17453 sec
Crashes Since Last Report: 10
Per-App Interval Since Last Report: 21 sec
Per-App Crashes Since Last Report: 7
Date/Time: 2009-10-03 14:56:34.733 +0200
OS Version: Mac OS X 10.5.8 (9L31a)
Report Version: 6
Anonymous UUID: DE541EC1-26E1-4685-8E6D-DFBCE46580F8
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000016fa3d98
Crashed Thread: 0
Thread 0 Crashed:
0 libSystem.B.dylib 0xffff07c7 __memcpy + 39 (cpu_capabilities.h:246)
1 ...ickTimeComponents.component 0x90cb692f _SGVideoGetChannelDeviceList + 2206
2 ...ickTimeComponents.component 0x90ca9bd0 _SGVideoComponentDispatch + 123
3 ...ple.CoreServices.CarbonCore 0x9420d935 CallComponentDispatch + 29
4 com.apple.QuickTime 0x960efd7c SGGetChannelDeviceList + 49
5 com.resolume.avenue 0x000c8bd5 0x1000 + 818133
6 com.resolume.avenue 0x000c6b6e 0x1000 + 809838
7 com.resolume.avenue 0x000c7082 0x1000 + 811138
8 com.resolume.avenue 0x00089238 0x1000 + 557624
9 com.resolume.avenue 0x0007ebc6 0x1000 + 515014
10 com.resolume.avenue 0x00019820 0x1000 + 100384
11 com.resolume.avenue 0x0001b864 0x1000 + 108644
12 com.resolume.avenue 0x00145c33 0x1000 + 1330227
13 com.resolume.avenue 0x00145e3f 0x1000 + 1330751
14 com.resolume.avenue 0x00019212 0x1000 + 98834
15 com.resolume.avenue 0x00002b92 0x1000 + 7058
16 com.resolume.avenue 0x00002ab9 0x1000 + 6841
Thread 1:
0 libSystem.B.dylib 0x91ab82e6 semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x91aea2af _pthread_cond_wait + 1244
2 libSystem.B.dylib 0x91b34aab pthread_cond_timedwait + 47
3 com.resolume.avenue 0x00219be4 0x1000 + 2198500
4 com.resolume.avenue 0x001dcb97 0x1000 + 1948567
5 com.resolume.avenue 0x000ab8ac 0x1000 + 698540
6 com.resolume.avenue 0x001dcc5e 0x1000 + 1948766
7 com.resolume.avenue 0x00220c9f 0x1000 + 2227359
8 libSystem.B.dylib 0x91ae9155 _pthread_start + 321
9 libSystem.B.dylib 0x91ae9012 thread_start + 34
Thread 2:
5 com.resolume.avenue 0x001dd4a9 0x1000 + 1950889
Thread 3:
0 libSystem.B.dylib 0x91ab8286 mach_msg_trap + 10
1 libSystem.B.dylib 0x91abfa7c mach_msg + 72
2 com.apple.CoreFoundation 0x95551e7e CFRunLoopRunSpecific + 1790
3 com.apple.CoreFoundation 0x95552b04 CFRunLoopRun + 84
4 ...le.QuickTimeUSBVDCDigitizer 0x1681e084 0x1681d000 + 4228
5 libSystem.B.dylib 0x91ae9155 _pthread_start + 321
6 libSystem.B.dylib 0x91ae9012 thread_start + 34
Thread 4:
Thread 5:
0 libSystem.B.dylib 0x91abf46e __semwait_signal + 10
1 libSystem.B.dylib 0x91ae9dcd pthread_cond_wait$UNIX2003 + 73
2 libGLProgrammability.dylib 0x92f46b32 glvmDoWork + 162
3 libSystem.B.dylib 0x91ae9155 _pthread_start + 321
4 libSystem.B.dylib 0x91ae9012 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x32332d06 ebx: 0x90cb60a2 ecx: 0x00000001 edx: 0x00000007
edi: 0x16fa3d98 esi: 0xbffff3e0 ebp: 0xbffff208 esp: 0xbffff200
ss: 0x0000001f efl: 0x00010292 eip: 0xffff07c7 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x16fa3d98
Binary Images:
0x1000 - 0x3abfed +com.resolume.avenue 3.1.2 (3.1.2) <2eeb499021d706107a7d70251c118fbe> /Applications/Resolume Avenue 3.1.2/Avenue.app/Contents/MacOS/Avenue
0x42d000 - 0x44aff7 com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x462000 - 0x52bfe5 com.apple.DiscRecording 4.0.7 (4070.4.1) <7c105f35c674aad3a476f8959d3f3ebb> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x596000 - 0x5b0ffd +net.sourceforge.glew ??? (1.4.0) <be16a519e2276149fbf11011d1b3953f> /Applications/Resolume Avenue 3.1.2/Avenue.app/Contents/Resources/GLEW.framework/Versions/A/GLEW
0x5c8000 - 0x5e7fed com.apple.audio.CoreAudioKit 1.5 (1.5) <82f2e52c502db7f3b32349a54209a0fe> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x5f9000 - 0x69afe7 +com.eltima.FlashInApp 2.0 (2.0.13.112) <cb904f086b9e41281f7b4c60395e7709> /Applications/Resolume Avenue 3.1.2/Avenue.app/Contents/Frameworks/FlashInApp.framework/Versions/A/FlashInApp
0x6c8000 - 0x6e6fe3 libexpat.1.dylib ??? (???) <eff8a63a23a7d07af62b36fdb329e393> /usr/lib/libexpat.1.dylib
0x103b000 - 0x103cfe1 com.apple.textencoding.unicode 2.2 (2.2) <542f2b8930d6bdf16c318ffea541acab> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x14670000 - 0x14672ff3 com.apple.LiveType.component 2.1.4 (2.1.4) <d60e25373b47ea9900776ce394378d07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x14678000 - 0x146dcfe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <1509b3ff8573ca6e914a6701f10c2159> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x146fa000 - 0x14740ffb com.apple.motion.component 1.0 (687) <b2fd93af0488c687c7b5a8fc8ae2d40c> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x14746000 - 0x14748ff7 +Motion ??? (???) <ba03f73fdcb26b738ebd87c2a5a93317> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x1474e000 - 0x147eaff8 com.apple.procore.framework 4.0 (712) <09ee33b4412cfc2553561de47695baa6> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x14dc0000 - 0x14fc7fef com.apple.RawCamera.bundle 2.1.0 (474) <48a574d3b3269c8dbdc38d6f67879317> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x155ff000 - 0x15696ff2 +com.motu.FireWireVideo.vout 1.1.1 (1.1.1 ) /Library/QuickTime/MOTUVOut.component/Contents/MacOS/MOTUVOut
0x166f1000 - 0x16702fe7 com.apple.DVCPROHDVideoDigitizer 1.3.2 (1.3.2) <6c25fc0fd39e2036db0953046983ece0> /Library/QuickTime/DVCPROHDVideoDigitizer.component/Contents/MacOS/DVCPROHDVideoDigitizer
0x1670a000 - 0x1676ffe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <94c8ca828e8df23f0771d065994a65d3> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x16789000 - 0x167c4fff com.apple.QuickTimeFireWireDV.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x167d1000 - 0x167dafff com.apple.IOFWDVComponents 1.9.5 (1.9.5) <889959011cb23c11785c378264400284> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x167e4000 - 0x16812ff7 com.apple.QuickTimeIIDCDigitizer 7.6.4 (1327.73) <f8ff5aa3fa49dcc1329986e6df5a780b> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/MacOS/QuickTimeIIDCDigitizer
0x1681d000 - 0x1686bffe com.apple.QuickTimeUSBVDCDigitizer 2.3.2 (2.3.2) <dceb65eeab48361f6466fadf8aa4ad6f> /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component/Contents/MacOS/QuickTimeUSBVDCDigitizer
0x16879000 - 0x16882ff7 com.apple.iokit.IOUSBLib 3.4.9 (3.4.9) <6ad6f7263d6163cde0da9c7146b9e121> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x1688c000 - 0x16a11fe3 GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x16a3f000 - 0x16da8fe8 com.apple.GeForce8xxxGLDriver 1.5.48 (5.4.8) <880ed3155078052260ade6e705c9ca64> /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
0x170e3000 - 0x170ffff7 GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x8fe00000 - 0x8fe2db43 dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
0x90003000 - 0x90009fff com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9000a000 - 0x9000ffff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x90010000 - 0x90f60ff6 com.apple.QuickTimeComponents.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x90f61000 - 0x91018ff3 com.apple.QTKit 7.6.4 (1327.73) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x91037000 - 0x9104dfff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9104e000 - 0x9107dfe3 com.apple.AE 402.3 (402.3) <b13bfda0ad9314922ee37c0d018d7de9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x910d0000 - 0x9118afe3 com.apple.CoreServices.OSServices 228 (228) <bc83e97f6888673c33f86652677c09cb> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9118b000 - 0x911ccfe7 libRIP.A.dylib ??? (???) <ec9df25a1ca8d668bda92f2baf407958> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x911e5000 - 0x91212feb libvDSP.dylib ??? (???) <b232c018ddd040ec4e2c2af632dd497f> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91213000 - 0x9124dfe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9124e000 - 0x912dbff7 com.apple.framework.IOKit 1.5.2 (???) <7a3cc24f78f93931731203854ae0d891> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x912dc000 - 0x914adffb com.apple.security 5.0.5 (36371) <1f7f48b36bc90d114220cc81e4e4694f> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x914ae000 - 0x917b6fe7 com.apple.HIToolbox 1.5.6 (???) <eece3cb8aa0a4e6843fcc1500aca61c5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x917b7000 - 0x917c1feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x917cc000 - 0x91905ff7 libicucore.A.dylib ??? (???) <dd8aa51c356e79ef8cdfa341a0d69f5b> /usr/lib/libicucore.A.dylib
0x91906000 - 0x91983fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91a65000 - 0x91ab6ff7 com.apple.HIServices 1.7.1 (???) <ba7fd0ede540a0da08db027f87efbd60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91ab7000 - 0x91c1eff3 libSystem.B.dylib ??? (???) <ae47ca9b1686b065f8ac4d2de09cc432> /usr/lib/libSystem.B.dylib
0x91c1f000 - 0x91d00ff7 libxml2.2.dylib ??? (???) <4d54971007e14f8d80e6889ee1111f21> /usr/lib/libxml2.2.dylib
0x91d01000 - 0x92111fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92112000 - 0x9213bfff libcups.2.dylib ??? (???) <764c74a71785aa10f3cac2eae06f372b> /usr/lib/libcups.2.dylib
0x9213c000 - 0x921ecfff edu.mit.Kerberos 6.0.13 (6.0.13) <804bd1b3f08fb57396781f012006367c> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x921ed000 - 0x9237cfe7 com.apple.CoreAUC 3.08.0 (3.08.0) <276d2dc9250afad7868a50e3b283b1f2> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9237d000 - 0x923fcff5 com.apple.SearchKit 1.2.2 (1.2.2) <3b5f3ab6a363a4d8a2bbbf74213ab0e5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9243a000 - 0x92459ffa libJPEG.dylib ??? (???) <50b881dd5a5795d38405c9c88c2806fa> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9245a000 - 0x92521ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x927f2000 - 0x927f9ff7 libCGATS.A.dylib ??? (???) <fb7677501dd491ea5520291045153069> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x92914000 - 0x9292cfff com.apple.openscripting 1.2.8 (???) <572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9292d000 - 0x9292dffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9292e000 - 0x929d5fec com.apple.CFNetwork 438.14 (438.14) <5f9ee0430b5f6319f18d9b23e777e0d2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x929d6000 - 0x92a14fff libGLImage.dylib ??? (???) <a6425aeb77f4da13212ac75df57b056d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x92b1c000 - 0x92b31ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92b32000 - 0x92bb9ff7 libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
0x92d38000 - 0x92dcbfff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92dcc000 - 0x92f1eff3 com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92f1f000 - 0x933f0fbe libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x933f1000 - 0x93581fff com.apple.JavaScriptCore 5531 (5531.5) <3679fe16241dae6f730a39c16c04e30f> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x93587000 - 0x93587ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x93588000 - 0x9358cfff libGIF.dylib ??? (???) <3c7100e80b7f7ca8809cf9512c1a6004> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x936ec000 - 0x93766ff8 com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x93767000 - 0x9377fff7 com.apple.CoreVideo 1.6.0 (20.0) <587c9c8966070a7d50276db35e1c76aa> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x939af000 - 0x939afff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x939b0000 - 0x939bcff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x939bd000 - 0x939dbfff libresolv.9.dylib ??? (???) <a8018c42930596593ddf27f7c20fe7af> /usr/lib/libresolv.9.dylib
0x939dc000 - 0x941dafef com.apple.AppKit 6.5.9 (949.54) <4df5d2e2271175452103f789b4f4d8a8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x941db000 - 0x944b5ff3 com.apple.CoreServices.CarbonCore 786.11 (786.14) <d5cceb2fe9551d345d40dd1ecf409ec2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9461a000 - 0x94625fe7 libCSync.A.dylib ??? (???) <94faf3571527a99d0a8809024aa9e1be> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94626000 - 0x94665fef libTIFF.dylib ??? (???) <801873cbd85ba7bdfe7646fe97a54ca3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94666000 - 0x94669fff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9466a000 - 0x946f7ff7 com.apple.LaunchServices 292 (292) <a41286c7c1eb20ffd5cc796f791070f0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x94728000 - 0x9472cfff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x94774000 - 0x94790ff3 libPng.dylib ??? (???) <271373dd41f56369a3dfca0ed2be579a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94791000 - 0x94871fff libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x948a4000 - 0x94c41fef com.apple.QuartzCore 1.5.8 (1.5.8) <a28fa54346a9f9d5b3bef076a1ee0fcf> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94c42000 - 0x94c42fff com.apple.Carbon 136 (136) <27d42531a2cbeb05a7f4d05a28281bd7> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x94c43000 - 0x954cffff com.apple.WebCore 5531 (5531.9) <fdb731afe66ea9ae2f4580dead0b5b53> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x954d0000 - 0x954deffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x954df000 - 0x95612fe7 com.apple.CoreFoundation 6.5.7 (476.19) <a332c8f45529ee26d2e9c36d0c723bad> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x95613000 - 0x9563cfff com.apple.CoreMediaPrivate 15.0 (15.0) /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x9563d000 - 0x958b9fe7 com.apple.Foundation 6.5.9 (677.26) <c68b3cff7864959becfc7fd1a384f925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x958ba000 - 0x958cafff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x958fe000 - 0x95900ff5 libRadiance.dylib ??? (???) <aefd52482869bb5010672679d151167e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95901000 - 0x95cbffea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95cc0000 - 0x95d00fff com.apple.CoreMediaIOServicesPrivate 20.0 (20.0) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x95d01000 - 0x95d25fff libxslt.1.dylib ??? (???) <0a9778d6368ae668826f446878deb99b> /usr/lib/libxslt.1.dylib
0x95d26000 - 0x95d51fe7 libauto.dylib ??? (???) <42d8422dc23a18071869fdf7b5d8fab5> /usr/lib/libauto.dylib
0x95e36000 - 0x9615cfe2 com.apple.QuickTime 7.6.4 (1327.73) <96515f6a2d628cd2105c7082295199b5> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9615d000 - 0x96238fe7 com.apple.WebKit 5531 (5531.9) <36112647223b999a033bc2f740277948> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x96239000 - 0x9623affc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x9623b000 - 0x962ceff3 com.apple.ApplicationServices.ATS 3.7 (???) <a535fc4982d3acff6530ec25c402e679> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x962cf000 - 0x962dcfe7 com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x962ed000 - 0x9632ffef com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x96375000 - 0x963cfff7 com.apple.CoreText 2.0.4 (???) <f0b6c1d4f40bd21505097f0255abfead> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x963d0000 - 0x96419fef com.apple.Metadata 10.5.8 (398.26) <e4d268ea45379200f03cdc7c8bedae6f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9641a000 - 0x96502ff3 com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9661a000 - 0x9661affd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9661b000 - 0x96622fff com.apple.agl 3.0.9 (AGL-3.0.9) <2f39c480cfcee9358a23d61b20a6aa56> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x96623000 - 0x9676bff7 com.apple.ImageIO.framework 2.0.6 (2.0.6) <7f73ef328c8e8566f3f204b5a540a7f0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9678b000 - 0x96792fe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x96793000 - 0x96795fff com.apple.securityhi 3.0 (30817) <31baaf7ea27b41480604ffc910fe827f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x96796000 - 0x9683dfeb com.apple.QD 3.11.56 (???) <a94d0f5438b730e88e5efdb233295c52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9684e000 - 0x96855ffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x96856000 - 0x968e0fe3 com.apple.DesktopServices 1.4.8 (1.4.8) <a6edef2d49ffdee3b01010b7e6edac1f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x968e7000 - 0x968e7ff8 com.apple.Cocoa 6.5 (???) <e064f94d969ce25cb7de3cfb980c3249> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x968e8000 - 0x968f4ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x96a76000 - 0x96a76ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x96a77000 - 0x96a80fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <73cf6b3c5ddf94d7ce9ae2c81c1b558c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x96a81000 - 0x96adaff7 libGLU.dylib ??? (???) <a3b9be30100a25a6cd3ad109892f52b7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x96adb000 - 0x96b37ff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x96b38000 - 0x96c03fef com.apple.ColorSync 4.5.3 (4.5.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96c0a000 - 0x96c12fff com.apple.DiskArbitration 2.2.1 (2.2.1) <75b0c8d8940a8a27816961dddcac8e0f> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x96c48000 - 0x96ca5ffb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x96ca6000 - 0x96ca6ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x96cc4000 - 0x96cfbfff com.apple.SystemConfiguration 1.9.2 (1.9.2) <8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x96cfc000 - 0x96cfcffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x96d4f000 - 0x96d77ff7 com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x96d78000 - 0x96df5feb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <782a08c44be4698597f4bbd79cac21c6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x96df6000 - 0x97496fef com.apple.CoreGraphics 1.409.4 (???) <b9a8a94c430d3b6f9ed7e2e4f0aad02c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x97497000 - 0x974a7ffc com.apple.LangAnalysis 1.6.5 (1.6.5) <d057feb38163121ffd871c564c692804> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x974a8000 - 0x9755affb libcrypto.0.9.7.dylib ??? (???) <9d714c92872a93dd127ea8556b2c8945> /usr/lib/libcrypto.0.9.7.dylib
0xba900000 - 0xba916fff libJapaneseConverter.dylib ??? (???) <b9aea83b1cd97f3230999ebfcbf63e7c> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbad00000 - 0xbad01fff libLatin2Converter.dylib ??? (???) <7b7804a2455b24ef3ba25aa8685a2923> /System/Library/CoreServices/Encodings/libLatin2Converter.dylib
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
Re: Res3 Crashes on launch on a macbook pro
It crashes when it tries to find out what cameras and capture devices are available. Do you have any exotic cameras, capture devices or software installed?
heppner
Post by heppner »
I have installed Final Cut Studio 3 and drivers for MOTU V4HD (I/O interface),
but V4HD is not connected when I want to launch Resolume.
