I've just downloaded the latest (trial) version of Resolume Avenue and each time when I want to tell one of my clips it has to BPM sync the image freezes, when I put it back to 'timeline' there is no problem.
In the previous versions I didn't had any problems with this.
I'm working on:
Imac 24", 3.06GHZ, 4GB Ram
Snowleopard
tnx
						Problem with BPM on snowleopard
Re: Problem with BPM on snowleopard
Is your BPM clock running? It might be that the clock isn't active, this means that your audio device isn't setup properly. Could you check this?
Hi Edwin,
I'll check it after the weekend!
Hi I have the same problem. The BPM clock is not running.
What is the relation with the audio device and how can I check/fix this?
Regards,
Tried this on a MacBook Pro Snow Leopard, no go. Same MacBook Windows 7, no problems.
Regards,
The new 3.1.3 version fixed this.
You guys are great, thx.
