Resolme 2.4 PC vs Resolume 3.1.1 Mac
Rougeballon
Post by Rougeballon »
hi, I´, from Argentina so my english is quite bad, sorry about that. I´m looking for a laptop, because I use Resolume 2.4...but I would like to know if someone had use resolume 3.1.1 on Macbook Pro? Has it any problem?
Re: Resolme 2.4 PC vs Resolume 3.1.1 Mac
Hi Rougeballon
Resolume Avenue runs fine on Mac OS Tiger, Leopard and Snow Leopard. Be sure to download the latest version for OSX (3.1.2) from the downloads section!
Let us know if you have any questions!
Rougeballon
Hi, thanks for answer...but I download the last version 3.1.2 in a Mackbook Pro and I have some problems... for example, supous I have 2 clip in a layer (I test it with the demo clips) when I want to change from one clip to another , it has a delay..i click, double click, and after some secons, it change me the clip...but you Know that this delay is a problem when you are mixing...
Also I have a very good desk pc windows XP...and I download de version 3.1.1 for that..and I have the same problem
I used to work with 2.4...but I was thinking in buying a Mackbook pro, so I star to test the 3.1.2 version...and the other part you´ve already know
GeeEs
Post by GeeEs »
The democlips are all combined with audiofiles in the demodeck... and all BPM synced.
The delay is normal in this mode, while the clip is waiting to jump in on the first beat!
Set the clips to "timeline" mode (in the clip properties) and they will start exactly on the moment you trigger one.
Enjoy!
Rougeballon
You are right!!!! genius!!!! thanks a lot...I was drown in a teacup ajaja
thanks a lot !!
BYE!
jim
Post by jim »
I must admit that got me too, when I first played around with avenue, put me off upgrading for a while.
