recording with resolume
pookie_
Post by pookie_ »
am just wondering how i can improve the playback of stuff i've recorded on resolume.
I've recorded stuff smoothly but when i play it back it jitters like mad.
have tried playing with the framerate setting but it didn't seem to help.
any suggestions greatly appriciated.
malco
ether_warpTV_
Post by ether_warpTV_ »
clips recorded in resolume are uncompressed so will have a very high data-rate (and therefore not play back great). They need to be re-encoded into whatever codec you usually use for your clips to be of most use in the mix.
pookie_
Post by pookie_ »
fantastic, cheers ether
cat_
Post by cat_ »
If you got 2 PC's get an analogue capture card and record what you see!
I run hires and capture hires, its ace!
