Standard Macbook pro good enough for avenue?
vide0junki3
Post by vide0junki3 »
Hey,
I'm new to Vjing, have my first gig coming up and need some advice on a laptop/
Is the 13" Macbook Pro good enough to run resolume comfortably?
13-inch: 2.53GHz
Intel Core 2 Duo
4GB Memory
250GB hard drive1
SD card slot
Built-in 7-hour battery2
NVIDIA GeForce 9400M graphics
What do people do to get a composite out? has the cable/adaptor problem been overcome?
VJair
Re: Standard Macbook pro good enough for avenue?
Post by VJair »
vide0junki3 wrote: What do people do to get a composite out? has the cable/adaptor problem been overcome?
a scanconvertor. ( add a few hundred £ to your shopping list for it )
vide0junki3
http://www.amazon.co.uk/s/ref=nb_ss?url ... er&x=0&y=0
would any of these work? if someone who is using a macbook pro and scanconverter could give me a url to a few recommended/tested scanconverters that would be great :)
HerrNieDa
Post by HerrNieDa »
instead of Standard Macbook pro with 9400m geforce, which uses ram for graphics memory you can also buy a normal new macbook... should be the same performace in resolume...
i hate the new macbook series - just my thought ;)
http://www.avtoolbox.co.uk/avt3155.shtml
This one is recommended by a few folks on vjforums.com.
It's generally a good idea to check out the several threads they have on the subject there: http://vjforums.com/showthread.php?t=30431
vide0junki3
thank you joris. very much appreciated :)
Stickygreen
Post by Stickygreen »
get the MBP that has the GT9600 video card, then you have dedicated video ram, it's worth the extra cost
