really like the matrox dualhead features..... because (acording to the webiste) you can conect two monitors at the same time, or a monitor and a tv , etc ,etc.... allowing you to extend your desktop into another screen.
i noticed that the ATI dual head features dont seem that good. it offers no zoom... and correct me if i'm wrong.... it seems to be able to conect either a VGA or DVI and a TV, but not able to conect 2 VGA... is this true????
wich should be the best choice fro resolume?
Ciao
ATI vs. MATROX
ether_warpTV_
Crackhead_
Elektron_
You can use two vga output at the same time on ati cards,
but u will experience some disadvanteges of the dual monitor settings. I wander why such a great manufacturer didn't create some working driver:( I have sucked so much with the ati dual monitor settings, like crashes, etc...
But it needs the corect dirver I think.
mariuski_
hello, I am almost ready to buy laptop ASUS with RADEON
card eaither Radeon 7500 or Radeon 9000. I have found
on ATI website both cards supports multi-monitor settings
however I would very much appreciate if someone with ASUS having either of the Radeon card could confirm the dual monitor funtion works fine.
I have tried setup multimonitor function on DELL Latitiude D600 with Radeon 9000 but I was not able to have different applications on the LCD laptop monitor and VGA external monitor at the same time...
DOES it mean that on LCD and external VGA monitor I must have same display and to see multi dispaly effect I must have connected projector or TV thru video output /s-video or chinch/ ?
t3rrorbit_
hello
ich have a radeon 9000 mobility with 64mb in my laptop and have no troubles with it, i can connect a second monitor to enlarge the desktop ore use it a cloned monitor or as dvd max screen, at the same time i can connect a tv screen and can even choose what to do with it, i can clone the first screen or make an enlargment or dvd max screen.
using the tv-out needed a bit of work because of this black borders, i had to install readeon tweaker and activated overscan, thats it
i like my radeon and have no problems, i am running my notebook at party for about 12 hours using resolume and a mp3 recordingsoftware, there were no crashs for about 20 acts
kyle_
carlos_
WoOofer_
