used macbook pro...what do you think?
sineglutine
Post by sineglutine »
Hi guys
could have, as used, this:
http://www.apple-history.com/?page=gallery&model=mbp
I have the ability to keep several days in trial
What do you think?
and the video card?
thanks!
sines
HerrNieDa
Re: used macbook pro...what do you think?
Post by HerrNieDa »
videocard is very poor, i have the same in my laptop and not even PAL-resolution runs fine with 3 layers and effects....
