Great news from the FreeFrame front!
edwin
Post by edwin »
Finally there seems to be a wave of creativity on the FreeFrame front. We were afraid that after the great success of FreeFrame classic (thanx Jaymis for the nomenclature), FFGL, the younger, quicker and better looking brother, didn't seem to be picked up by a lot of people.
We have been adding more and more plugins in every point release of version 3 we made in the last year, so at least people have a decent base to work with. Of course it would be nice if there were some more plugins to choose from.
In the last few weeks big steps have been taken to make it easier for developers to create plugins.
So here are the goodies, take what you like and let us know your experiences.
OpenFrameworks ofxFFGlPlugin add-on
Daniel Berio made an OpenFrameworks wrapper that converts your OF projects to FFGL plugins.
Use the versatile and developer friendly OF libraries to create plugins within minutes, Daniel's add-on is plug and play, an example for a source and effect plugin are included.
http://code.google.com/p/ofxffglplugin/
FFGL wrapper for FreeFrame classic from BigFug
A lot of people want to use their favorite FreeFrame plugins in version 3 of Resolume. With Alex May's (BigFug) FFGL wrapper now you can. So the all time popular plugins from Pete Warden http://www.petewarden.com/ can now be used in Avenue.
Check the vjforums post from Alex
http://bit.ly/8Z3EGP
and the CDM post
http://createdigitalmotion.com/2010/03/ ... gwrappergl
FFGL fugStream plugin from BigFug
This plugin enables you stream the output of a FFGL/FreeFrame classic host to another. Connect Resolume 2, Vjamm or vvvv to Resolume 3 or vice versa.
http://bit.ly/dkRrHD
FFGL fugCompilerGL plugin
Alex has been busy, check out this cool plugin.
If you fancy creating your own FFGL plugin, but don't want to mess about with C compilers, then this one is for you.
fugCompilerGL allows you to create your own FFGL plugins by just writing vertex, fragment, and geometry shaders.
gpvillamil
Re: Great news from the FreeFrame front!
Post by gpvillamil »
Wow, awesome.
All of this is great news. I had been wrestling with FFGL and Open Frameworks, and the new toolkit really helps!
bigfug
Post by bigfug »
There's a new version of fugWrapperGL out (1.0.2) which fixes all of the currently reported issues.
Enjoy.
Best wishes,
Alex
HerrNieDa
Post by HerrNieDa »
i just tried the wrapper.. seems to work so far that i have the effects in the list, but they don't do anything in resolume!
there is also a source and 2 normal fug ffgl plugins... i tried around but did'nt get it...
what am i missing? :oops:
Tschoepler
Post by Tschoepler »
“This app has failed to start because swscale-0.dll was not found. Reinstalling this app may fix the problem.”
I am running Win7 x64 and Resolume 3.1.3 with fugWrapperGL 1.0.4
By the way: I had to turn off the UAC (user account control) to run the batch. Right clicking and running as administrator didn’t do the job.
Anyway: THX so far. Looking forward to seeing this piece develop.
edit: just throw the files into the resolume install dir and it'll work just fine.
francoe
Post by francoe »
Great!
There's a new release of the wrapper that Im trying right now.
Cuz the early versions doesn't work with the pete plugins. In facts, just work with a couple of plugins.
But the last week I spend several hours trying to code some shades, and I enjoy it a lot. That compiler is an awesome tool.
craftycurate
Post by craftycurate »
Tschoepler wrote:“This app has failed to start because swscale-0.dll was not found. Reinstalling this app may fix the problem.”
The HTML help file explains how to install properly - I had this problem initially but I had not spotted the Help file.
meerkat82
Post by meerkat82 »
I can't even see the list of effects. I've followed the directions in the helpfile & installed the update. When I run the batch file I can see that access is being denied to the .dll files. If I run the batch file as an administrator I see a "do copy" command and address. I am running Windows 7 64 bit.
francoe
Post by francoe »
meerkat82 wrote:When I run the batch file I can see that access is being denied to the .dll files.
Can you be more specific about that?
Im not in win7, so.. maybe a windows warning about ejecution rights?
Tschoepler
meerkat82 wrote:I can't even see the list of effects. I've followed the directions in the helpfile & installed the update. When I run the batch file I can see that access is being denied to the .dll files. If I run the batch file as an administrator I see a "do copy" command and address. I am running Windows 7 64 bit.
As I mentioned earlier: you have to turn of the UAC (User Account Control) before starting the batch. Maybe it works with the "elevate" command, haven't checked yet.
Locked
