So if you have an ATI card you might have noticed that omega drivers quit updating a while ago...
And ATI doesn't release drivers for notebooks, leaves it up to notebook manufacturers.. which never update them.. The first trick I learned to update drivers is complicated and requires tools to mod the existing catalyst.. That is no good... Then I found cell-systems drivers, and was like OMG WTF O_o ... I installed enzyme for my mobility 4670 and now have full kuntRoll just like I should.
So it is called Enzyme,available here http://www.cell-systems.net/category/do ... msdrivers/
It even allows to switch openGL versions without having to reboot.. funstuff
new modded ATI drivers
pleasuretek
Asus build - intel 2.8GHz T9600, 4GB 800Mhz DDR2, ATI 4670
Rack unit - intel 2.7GHz q6600, 8GB 1066Mhz DDR2, 9800GTX+, intensity HDMI input card
