Resolume and Monome
				newfuturenow
Resolume and Monome
Anyone using a monome 64 alongside Avenue to full effect? is it easily configurable to work as a bank of pads to trigger clips and also give out led feedback as to which clip is triggered? Or will I find myself in the same situation as I do with my APC40. with a decent bit of kit that almost works perfectly but doesnt because of my inability to script midi?
						Re: Resolume and Monome
as of now midiFeedback is not implemented, and midi's are all on the same boat... be it apcs or monos... hopefully they'll implement it soon
