FX: global vs. individual
douglas_
Post by douglas_ »
Is there a way to hit a trigger and have it apply an effect to an individual clip instead of globally? It seems that now, even if an individual clip is selected, when you apply an effect via MIDI (as opposed to manually dragging the effect to the clip), it affects the global output. But maybe there's another way...
This would be a cool feature to add for 1.1, if possible.
you can apply an effect to the active channel by pressing CTRL & 'effect shortcut' ...
1.1 will feature a LOT more midi functions ... we never expected that so many people are using midi ...
douglas_
Post by douglas_ »
What would also be cool is if Resolume could be *totally* opearted via MIDI -- this would only require the ability to control the individual FX via midi (i.e. if you could replace the CTRL key with a midi key) and if you could select/scroll through the saved decks via midi. Then you wouldn't need to touch the computer at all, except to start up and shut down...
