On the Resolume 2 Manual, it is written:
"Resolume can use multiple displays to show different content on different screens. You can show different content on the displays by routing different layers or layer combinations to different displays. This way you can for instance show the resolume interface (with a small preview) on a monitor in front of you. And then show the combination of layer 1&2 on projector 1 and show layer 3 on projector 2. Or if you have 4 displays you can use one for the interface and send the 3 different layers to 3 different projectors."
I don' see at all how to do that with Resolume 3 !
Is there anywhere an option that enable to tune which layer go to one display ?
For the current project I work on, I can't use different parts of the global composition for the two displays, because I need two totally separate display (for instance, I don't a zoom in Display 1 come across my Display 2).
I spend two days on this problem, that is due to the impossibility to apply mas after layer composing of effects.
Thank you by advance for your help !
Yves-Marie
