Auto Crossfader 0.1 /// MAX patch
Tschoepler
Post by Tschoepler »
and another one. it has two modes: step–sequence and random.
Avenue Auto Crossfader 0.1.zip
0.1! don't expect too much ;)
(49.72 KiB) Downloaded 793 times
vmartins
Re: Auto Crossfader 0.1 /// MAX patch
Post by vmartins »
Hi, just tested your program...
I't doesn't seem to work in "sequence mode" either the "fade time".
maybe I just don't know how to work with it, I need the user manual.
thanks for the great work...
Tschoepler
SEQUENCE–MODE
1. set length of pattern to e.g. 8
2. change the zeros to either 1(crossfade to B) or -1(crossfade to A)
3. set fade time to 250(ms)
4. toggle on/off
5. beat int is set to 1 by default (although 0 is shown). if for example you raise beatint to 4 then it takes 4 times as long for the sequencer to progress. in this case one step of the sequencer = 4 beats. I implemented this in case 16 steps is not enough.
RANDOM–MODE
1. toggle on/off
2. that's all.
Basic
Post by Basic »
cool looking forward to testing this when new lappy is on the way!!!
Charlastro
Post by Charlastro »
Many thanks for your work, Tschoepler, I find the auto-crossfader extremely useful.
A couple of minor suggestions / requests for future development..
1. Might it be possible add a midi clock input, similer to the one used in zuvassin's version of the step sequencer?:
http://www.resolume.com/forum/viewtopic ... cer#p28032
I'd love to be able to send Traktor's midi clock to this patch.
2. It would be useful to have a button which jumps the seqencer pattern back to the first square. You may have, let's say, a 16 beat pattern which is perfectly in time with the beat but starts on the second beat of the bar.. it would be good to be able to jump it back so it starts on the first beat of the bar.
Regards
charlastro
