Quicktime DXV Codec and After Effects rendering crash...
Straight-Disorder
Post by Straight-Disorder »
Hello,
that's my worry,
I prepare sequences 1920x480px (broadcast on three screens via Matrox TripleHead2Go), for certain I would pass by After Effects (CS5) and do it with QuickTime codec DXV.
I tried several settings but nothing to do, the rendering crash starts almost immediately and by the same crash used After Effects.
No problem if I work my data in any other format, it happens with QuickTime / DXV and I want to make my movies with this codec (terribly effective in Resolume! Despite the weight ..;) ) ...
It seems that the problem stems from a crash of "rendering module" QuickTime ... but why?
Are there any special settings to make in After Effects at the record ..?
Note that I also tested a single crop and export in DVX via AdobeMediaEncoder for the same result, crash after 2-3s of Treatment ..:-/
I have to go through my trusty Asus Laptop (XP Pro / / 2GB RAM //...) in QuickTime to encode / DXV (via AdobeMediaEncoder) prepared my data on my new PC in another format... not handy ..:-/
Does the fact that i have installed QuickTime freeware instead of QuickTime Pro may have an impact?
Is it simply a problem of RAM? (I intend to spend 8GB ...)
Motherboard Asus P6T Deluxe V2
Pentium 2.80 GHz quad core i7 930
Video Card NVidia GTX470 1280Mo
2x2GB DDR3 Ram (soon 4x2Go ...)
Hard Drives (x2) Western Digital 7200 Sata / / 32MB cache / / 640GB (x2)
O / S Windows 7 / / 64bit
In the hope of receiving help from you,
cordially,
Pascal
aka V.JaX
http://www.straight-disorder.net
STRAIGHT DISORDER
[Audio-]Visual [Live] Works
contact@straight-disorder.net
Re: Quicktime DXV Codec and After Effects rendering crash...
We have sent you a private beta version that should fix this. We hope to release this as DXV version 2.2.1 asap.
Straight-Disorder
codec 2.1.1 beta works great, no more problems, thank you!
STRAIGHT DISORDER
ABDXVUSER
Post by ABDXVUSER »
I received the same rendering error in AE CS5, and I'm glad to see someone addressing it here as well. I feel like this isn't necessarily unique to DXV--I'm about 90% positive something identical happened with H.264 as well (I was on a deadline where everything seemed to be going wrong, so it may have just been me getting flustered). Regardless, I'm attaching the dialogs that appeared for me--I blacked out the file name so as not to clutter. Similar to the previous poster, this happened within the first few frames of the file.
The second of the dialogs after initiating a DXV render in AE CS5.
Render Warning-2.png (19.59 KiB) Viewed 15101 times
The first of the dialogs after initiating a DXV render in AE CS5.
Render Warning-1.png (26.66 KiB) Viewed 15101 times
DanieleKGuevara
Post by DanieleKGuevara »
I'm using After Efftects 6.5 and all is awesome, even when I go back and forth with other CS3!
Tschoepler
Post by Tschoepler »
It is working properly in AE CS4 but not CS5.
May I ask for that secret beta? :)
Godzil
Post by Godzil »
I have the same error rendering problem in Sony Vegas Pro 9.0 software :cry:
Basic
Post by Basic »
Godzil wrote:I have the same error rendering problem in Sony Vegas Pro 9.0 software :cry:
have you tried the new update? it should have fixed these issues.
http://www.resolume.com/download/
Tschoepler
Still the same error.
Updated QuickTime and DXV.
What about the others?
When you install Resolume 3.3.1 then the DXV codec is updated to the latest version that fixed the Vegas and AE rendering problems.
