Loosing saved deck settings???
lucidouse_
lucidouse_
Thanks for reply
i understand Edwin...
Is there a way in the future for this to be addresed..?
it has coused me some problems, eg: plugging my external harddrive into another system...
Something on te lines of an after effects project were it asks you for te new path/folder to the source material..if it can not find it or it has been moved
Morris
Morris
torsten_
by testing the tryout version 1.5.1 the prog looses information of the saved decks after restarting the programm. you can only see the thumbsnails, not the clips itself. i have to import the files again. after saving the deck, closing and restarting the prog, other clips are not evaluable.
this is very awful for preparing live events.
it does not work.
if someone has the same problems or solutions, please anwser ...
resolume feedback is not anwsering yet.
t.
it does not work.
t.
we hope that with the nexty version those problems will be taken care of.
In version 2.0 you will have a deck manager and a number of 8 possible decks directly accesible.
moving decks is not such a problem but moving the files that are adressed to in a deck is.
if you move a file the deck doesn't know where its is but will show a thumbnail because that is stored in the deck itself together with all the params and settings of your clips and effects.
cheers
cheers
