DVD-Max on Shuttle makes output bounce
ecin_
Post by ecin_ »
I recently noticed that the bottom half of my output bounces horizontally by a couple pixels. its not completely noticeable when theres a lot of movement but when my visuals slow down or pause its very obvious. it doesn't seem to happen with DVD-Max through windows media player or when just sending the output to the second monitor. its native to resolume.
anyone seen something similar?
beeZ_
Post by beeZ_ »
Yes i am having the same little shake, you are talking about when i am using the dvd-max function in resolume. And it is clearly noticeable when displaying slow footage or stills like a loge or something.
beeZ_
Post by beeZ_ »
logo
SirAlex_
Post by SirAlex_ »
Hello, I have the same problem it bounces a lot the bottom.
SuperficiaL_
Post by SuperficiaL_ »
hi guys,
DVD-Max is not really processor friendly i found out the first time i used it...
so i gues u can get all kinds of weird things happen to your video...
i advise that u try to output another way...
greetz,
SuperficiaL
ecin_
Post by ecin_ »
i have to disagree. my rig runs twice as fast with DVD-max than it does with the output set to the 2nd monitor.
SirAlex_
Post by SirAlex_ »
So??? ios there a solution for the problem?? What can whe do?? :P is there any driver that we can use or a path ?
ecin_
Post by ecin_ »
guess we'll have to wait and see if verison 2 works out the kinks.
