ViDock
digital:snot
ViDock
Post by digital:snot »
searched the forum for"ViDock" and was surprised to not find an entry.
now that resolume is largely GPU intensive, i am interested if anyone has re birthed and old laptop (or suped up a non-gaming laptop) with a supervideo card using one of these products:
http://www.villageinstruments.com/tiki- ... age=ViDock
and to the Resolume team: would there be a performance enhancement by outputting Res:Ave through a ViDock while using the GPU of the onboard videocard for the interface? (or do they need to coexist on the same card output+interface)
Tschoepler
Re: ViDock
Post by Tschoepler »
There is another interesting product here: http://www.cubixgpu.com/. But I guess this is Overkill.
Agent Orange
Re: ViDock
Post by Agent Orange »
There's also the option of a DIY ViDock, which gives you a cheaper, more flexible external video card for your laptop... although there's no enclosure :?
http://forum.notebookreview.com/gaming- ... ences.html
HerrNieDa
Re: ViDock
Post by HerrNieDa »
and what about this?
sadly just pci but maybe also a good solution
http://www.virtuavia.eu/shop/full-packa ... rrency=EUR
vjtk
Re: ViDock
Post by vjtk »
any word on this? Anyone? I'm looking to upgrade my W500 with a 1.5GB Nvidia card using the ViDock 4...
Mac Pro 8-Core 2.8 GHz, 8GB RAM, ATI Radeon HD 3870 512MB GDDR4, Leopard 10.5.5
Lenovo Thinkpad W500, T9400 2.53Ghz, 4GB RAM, ATI V500 FireGL 512MB, Windows 7 Pro
vjtk
Re: ViDock
Post by vjtk »
Here is a review of the ViDock
http://www.amperordirect.com/pc/r-resou ... eview.html
I'm trying to decide between this and the Matrox Triple Head 2 Go
Re: ViDock
And here is a bad review of the ViDock
vjtk
Re: ViDock
Post by vjtk »
seems like he likes it, except for the 24 hr setup time ;) I'm thinking the triplehead2go card is the way I should travel....
Re: ViDock
ehm? really? these are two completely different products.
ViDock >> Adds a full graficcard to your notebook (Own GPU)
MTH2Go >> Simulates a very large screen to your graficcard and cut and send the input signal to two or tree outputs. (No extra grafic performance)
Greets!
SystemD
Re: ViDock
Post by SystemD »
Does anybody have tested this case with Resolume 4 (on a macbook pro) and 2 graphics cards to be provided with 4 outputs to plug four projectors?
