videomixer
54lb3i_
Post by 54lb3i_ »
where can i get a not to expensive videomixer and/or a scanconverter?
...and wich one is the best (in your opinion)...
these kind of issues have been extensively discussed on http://www.vjforums.com / http://www.vjcentral.com
54lb3i_
Post by 54lb3i_ »
oke, thanks for your advice...
Graben 12_
Post by Graben 12_ »
hi!
we got our videomixer WJ-AVE 5 Panasonic from the world of ebay!!
-price about 120 €
it`s a simple mixer, but it works!
good luck for your surch
Graben 12
Xavi Vj_
Post by Xavi Vj_ »
I recommend you the EDIROL (Roland)V1 or V4 The V1 is simple and cheap. Also you can look for any VIDEONICS, I have 1 and it works fantastic!!
