Help me fix my Fullscreen display problem.
l'enregistreur
Post by l'enregistreur »
Hi evreyone,
I have trouble displaying on second monitor(VP).The desktop is extended correctly, but when fullscreen is activated, the video playing sort of stagg and doesn't play properly.
I have a NVIDIA Quadro FX1600M which run great with arkaos for instense...
dPlease don't tell me I have to change my card to play with resolume!!!My laptop is a dell precision M6300 strong enough to run such programs as i bought it in this purpose...
Please help needed!
cheers to all.
L'ENR.
HerrNieDa
Re: Help me fix my Fullscreen display problem.
Post by HerrNieDa »
which resolution do you use?
the graphic card should be fast enough ( a bit faster than an 9600 mobile gpu) but if you run full hd its maybe to much!
also, if you run for example 720p, your should set your monitor also to 720p and not full hd if he's able to, normally saves much performance!
l'enregistreur
Thanks for replying to my post!
First, i use the latest version of resolume.
I struggle again last night to get tru it with no success.I did tries with a basic res for output(800x600).I have troubles just to extend the desktop.
Should I only mahage dualview through the nvidia setup panel?Or also in the display setup of windows?That's a silly question but I ever ask myself this.
I installed the omega driver too just to see the difference.the pc crashed badly, so I took it off.
I tried to manege 3D global settings as described in the support page of the site but the panel is different from what's shown and can't find "compatibility mode".
At least if you say my card should be strong enough to hold the thing that's cool.
I am going back on it, tell me what you think according to these new elements and again, thanks for helping!
cheers
l'enregistreur
Hey again, I finally solved the problem!I found the "compability" option in the set up panel of nvidia which was named a bit differently...So it works now!I hope I won't have to struggle at each time from now.
Thanks a lot anyway for your interest!
