DXV with Matrox TripleHead + Geforce HD 6850 / which GPU?
Hey Resolumes,
I'm using a Win7 System with the Geforce HD6850 + Matrox TripleHead2Go
- - - - - - - - - - - - - DVI Out 1 --> Matrox TripleHead2Go -> 2x Screens
Geforce 6850 --|>>
- - - - - - - - - - - - - DVI Out 2 --> Acer touchscreen for operating.
my question:
I read that the DXV Codec calculate the to resolume imported clips on the GPU instead on the CPU. Right?
Sooo....when I look at my system, there are actually 2 GPU's. One on the Geforce and another on the matrox.
On wich GPU the codec forces the clips to be calculate on?
Greets
HerrNieDa
Re: DXV with Matrox TripleHead + Geforce HD 6850 / which GPU?
Post by HerrNieDa »
a matrox dual/triple head only generates one big screen with 2 or 3 screen connectors ;)
(it works not as graphic accelerator)
so the gpu work is always done by your main graphic card (btw. i think you have an ati radeon instead of an nvidia geforce :p)
hahaha. you're right! :-) tooo much beer yesterday.
