DIY Midi Controller - Has anyone tried MidiBox?
XNDR_
Post by XNDR_ »
Hi all!
I'm currently building my own VJ computer with built-in TFT screen and other cool options and I would like to build my own Midi controller. The midi controller will be specifically designed for Resolume. I've found a german site that sells modules for custom midi controllers: http://www.ucapps.de/ (Midibox.org)
Has anyone tried this yet? Recommendations and/or tips would be really helpful since the midi concept is pretty new to me...
levon_
Post by levon_ »
i want to make one of these, but havnt had much time/money to do this.
probably round chrismas time ill give it a try
norm_
Post by norm_ »
moin,
a friend of mine built one form me and it wokrs perfectly. He said the material cost about 50 euro. the most expansive part was the small LCD panel and the chase...
norm_
Post by norm_ »
moin,
site_
Post by site_ »
Yeah,
I'm working to build one for myself. Hooked up the bts n stuff its all working fine as a midi controller should be. Have yet to finish the casing for it though.
Spent about $300 i think on the whole project, that's cause its my first time with electronics. But i figured that if i know what i was doing (if i did a second one) the cost will be down by half.
Most parts is so easy to copy it off the schematics online that you don't need to buy any curcuit boards from anyone(the costly part for me).
site_
Post by site_ »
yeah, not to forget, many thanks to bart and edwin. The my layout is largely based on their midi controller.
Cheers
