Hi!
I have a problem with my iPad's TouchOSC and Resolume, that is Resolume doesn't respond at all to my commands from iPad. Both Resolume and TouchOSC ports are same 7000, bundles is turned off and OSC is enabled in Resolume.
I'm using iPad layout which could be found here: http://www.martin-thoburn.com/vj/touch- ... esolume-3/ . I have added the layout through TouchOSC editor.
Also, I have checked that my MacBook receives information to PD-extended via ad hoc wireless network.
I'm losing hope. This should be so easy to set up but I can't manage it. Could anyone help or does anyone have similar problems?
Problem with Resolume and TouchOSC?
julianvanbuul
Re: Problem with Resolume and TouchOSC?
Are you using a TouchOSC layout with custom commands? Apparantly, since the upgrade to TouchOSC version 1.7, the custom osc commands arent working anymore. You’ll have to wait for a new update, more information on the hexler site: http://hexler.net/forum/viewthread/31/
julianvanbuul wrote:Are you using a TouchOSC layout with custom commands? Apparantly, since the upgrade to TouchOSC version 1.7, the custom osc commands arent working anymore. You’ll have to wait for a new update, more information on the hexler site: http://hexler.net/forum/viewthread/31/
Thank you for your info! Now everything works fine and videos are on fire!
