Hi there,
I was wondering is it possible to load or add some of the transition effects that are in 2.41 into Avenue or to download them as extra plugins?
The transitions such as "slide open,slide close,squares,corners etc.. and the wipes that are available in 2.41.
I realize there is way more option to do control compositions in Avenue but I really liked some of these transitions/wipes.
Any help/advice would be very much appreciated.
Transitions effects in Avenue
Re: Transitions effects in Avenue
Oh yeah i remember those ones. good ole effects.
Is it not possible to do this with creating PNG masks and loading them into the composistion and using the layer opacity to control the transistion?
Just and idea and not at my VJ machine so can't check.
Thinking also having this effect built in would be great also!
im =1 for this.
im =1 for this.
