Sorry for a dumb question, but I really am confused now. I installed resolume 1.51 on a windows 98se machine. I also have the latest flash player plugin installed. The problem is that on my second windows xp machine everything from triggerMotion runs fine.
But on the win98 some of the flash loops don't seem to run (only a couple frames are displayed). What's even more strange, they run smooth under Internet Explorer.
Thank's in advance for any help in solving this problem.
Kind regards.
triggerMotion and win98+resolume 1.51
Jeremy_
SupericiaL_
hi Bill,
if a cuple of frames are displayed and since it plays well in your browser it couldnt be your flash player.
i think its directX or something.. dl the latest directX from windows.com...
i think that will help.
its either this or a standalone player problem(which would be weird because resolume doesnt use the standalone player...)
Bill Pindelski_
Thank's for your answers. I have directx 9.0b installed and use a radeon 7000 series graphics adapter. Macromedia says to me : Version 7,0,14,0 installed successfully (when installing flash player).
I'll try to tweak my graphics card and see what happens.
BTW, did anyone use the ffplugins-16-03-2004? I noticed that when I copy lumaedges.dll into my plugins dir, suddenly all plugins disappear. This is the only file that causes this error. Strange.
Bill Pindelski_
It gets weirder every minute. On my second PC with win XP I suddenly have the same problem. I think it started happening after I installed resolume 2 along with 1.51. In 1.51 the flash file plays normal when being held on the 8th frame (Dings_HippiStamps.swf). I now know that resolume has a problem with the "loading" scene that is inside this loop.
And speaking frankly - I don't know what to do.
Thank's for your help.
Kind regards.
Kind regards.
Bill Pindelski_
