My Intensity Pro Sources keeps changing its order in Resolume whenever I restart my computer.
Is it within the OS or is it the way Resolume loads the devices?
Thought I ask here, since you guys have the inside scoops on Intensity Pro api's .
BTW: I am running on a MAC with 6 Intensity Pros . All works well except the changing order stuff. It makes me reconfigure the cameras input. It is easier to rewire than to change my sources around, especially when the compositions are complex.
Just looking for a way around this ordeal.
						Intensity Pro Sources change order.
Re: Intensity Pro Sources change order.
Unfortunately this has to do with how your OS accesses the inputs, and not something we can do a lot about. The good news is that on Res4 we'll be using the BlackMagic SDK to access the inputs ourselves, so it shouldn't be a problem anymore.
				fruitygreen
Good news: There will be a fix of alot of things in Resolume 4.0.
Better news: The day it arrives.
With all the talk I hear about 4.0, when do we expect it?
Are we close? Near? Far?
Will it support Kinect? Hahaha!
Thanks for the insight.
Reso + Kinect ;] so good ;]
if use in Resolume 4,  SDK to the Vision RGB E2s capture card?
http://www.datapath.co.uk/
